The TRN BA5 is a pretty decent all-BA set, although the treble can be a bit harsh.Howdy friends, how are you?
Simple question: do you recommend any full balanced armature sets under $100 bucks? I already have the blon bl03 and the tin hifi t2 and never had a ba iem. I'm curious on how good/different they may sound. I read that they are good for detail retrieval but the timbre can sound unnatural.
Also, feel free to recommend any other iems that can complement my collection. Unfortunately, I don't own an amp or dac, so they will be powered by my Samsung phone and LG laptop.
That's all, peace.
CHIFI LOVE Thread-A never ending IEM-Heaphones-DAP-Dongles Sound Value Quest
- Thread starter NymPHONOmaniac
Barusu Lamperouge
Folks also rate KZ BA10 and ASF/X very highly as well. Do check on them as well.Howdy friends, how are you?
That's all, peace.
zenki
Check out Audiosense AQ0/DT100? whichever the BA one
RikudouGoku
Member of the Trade: RikuBuds
The DT100 isnt really a good BA iem to try as your first BA iem. Because it sounds so atypical from normal BAs that it might give you the wrong impression on them.Check out Audiosense AQ0/DT100? whichever the BA one
JEHL
Does this also hold true for the AS06?The DT100 isnt really a good BA iem to try as your first BA iem. Because it sounds so atypical from normal BAs that it might give you the wrong impression on them.
RikudouGoku
Havent heard it. The only ones like that is the Audiosense DT100 and the DT200 to a lesser degree.Does this also hold true for the AS06?
H T T
- May 11, 2013
The Fiio FA1 is a competent single BA IEM around $100.
NeonHD
Kbear just sent me their new KS1 on the house! Will provide an extensive review of it when it arrives.
Tonymac136
For the money, it's virtually a no-brainer (unless v shaped isn't your thing or you're a BA lover). For free, it's awesome.
Opps, typo $38. SorryWow! From where did you get them for $18?
1clearhead
- Apr 5, 2013
Discovering KZ and CCA budget kings!
https://www.head-fi.org/threads/the-discovery-thread.586909/post-16244495
Enjoy!
-Clear
Enjoy!
-Clear
Tonymac136
So the NICEHCK lucky bag that's doing the rounds at the moment is the NX7 Pro. At under £40 it's worth having I'd say. I've not really done much listening but the details seem better than on the likes of ZAX. Tuning with stock filters seems just a tad subdued with vocals and a tiny bit hot in the upper mids but maybe the bassier filters will fix this. They're the opposite of what I usually go for in that they have great technicalities but the tuning and timbre arent the very best, so they will play nicely with the rest of my collection.
Kumonomukou
I actually have different opinion on KBear KS1. They're not very technical or smooth, especially when volume is raised. They're indeed V shaped, decent baass quantity, sub-par bass definition, and slightly hollow vocal. They're not even better than VK4, or other CVJ buds in the price range. Definitely not better than the likes of Tin series or KZ ZS7 etc. build quality is very similar to the entrance KZ products. They're okay, do not stand out even in $20 category. Worth to be a beater set, but probably better options out there.
Are TFZ T2 galaxy better for EDM than KZ DQ6?
I don't have the TFZ T2 but I'll say that the DQ6 is excellent in general. Probably will need to do some tip rolling though.Are TFZ T2 galaxy better for EDM than KZ DQ6?
Total: 21 (members: 1, guests: 20)
