CHIFI LOVE Thread-A never ending IEM-Heaphones-DAP-Dongles Sound Value Quest
- Thread starter NymPHONOmaniac
RikudouGoku
Member of the Trade: RikuBuds
I only touched the bass with PEQ:When I had the Tin P1, I mated it my Monoprice/Monolith THX portable DAC amp. I only experimented with boosting the low shelf. Did you adjust your PEQ settings as well ?
I ask because I picked up another pair, in a trade.
Found that this also helps remove some of the unnatural treble timbre.
KaOni
Oh, at that price range I wouldnt recommend 8/16 core cables. I got a few cables like that over a year ago and they are all built very poorly. I recommend you get something like the Faaeal litz copper cable that is at 14 usd now on 11/11, it is 4-core cable but build quality and measurements are amazing.
How do you compare it versus TRN T2 16-core silver-plated copper cable? @RikudouGoku
With coupons I can get the TRN T2 16-core for like 7€!
IEMusic
In general, TRN cables are not built as well as KBEAR and NiceHCK cables are, IMO, so longevity is in question.How do you compare it versus TRN T2 16-core silver-plated copper cable? @RikudouGoku
RikudouGoku
Agree, trn stuff are not very good In terms of QC. I don't have the T2 but got the T3 and I think the Faaeal are better built.In general, TRN cables are not built as well as KBEAR and NiceHCK cables are, IMO, so longevity is in question.
stryed
I bought the KBEAR LARK, as a very spontaneous buy!
Had coupons for another deal and decided to place the savings on some IEMs..
My best cheap ones are the CA C12, which have held up. The newer Ibasso IT00 did peak my interest after the wholesome IT01, so this KBEAR purchase is a gamble (probably helped by wine).
I wanted to test this C12.
PhonoPhi
ZAX supercedes C12 and ZSX now, in my opinion.I wanted to test this C12.
ShakeThoseCans
I'll sell you mine!
Oh damn, you're in Brazil.
I'll sell you mine!
Yes, it gets really complicated haha
stryed
That's good to know. For me C12 lacked a bit of timber, especially in the bass area. All considered, a good purchase.I wanted to test this C12.
LARK seems a bit of a gamble.. Will see!
I don't really care about the number of drivers, as my best performer is a single DD.
countryboyhk
- Aug 20, 2010
My BL-01 arrived, solid build and weighted. Not have BL03 anymore ( never heard of bl05, bl05s ), but first impression of BL-01 is good, more transparent sound, wider soundstage. I feel it's an upgrade from BL03
RikudouGoku
How is the fit? Seems better than the 03 at least.My BL-01 arrived, solid build and weighted. Not have BL03 anymore ( never heard of bl05, bl05s ), but first impression of BL-01 is good, more transparent sound, wider soundstage. I feel it's an upgrade from BL03
SiggyFraud
I see you changed the tips to Azla Sednas. Is it due to bad fit?My BL-01 arrived, solid build and weighted. Not have BL03 anymore ( never heard of bl05, bl05s ), but first impression of BL-01 is good, more transparent sound, wider soundstage. I feel it's an upgrade from BL03
countryboyhk
- Aug 20, 2010
better fit than 03. It's better than TRN VX and Tri i3 as well
