Fat Larry
I think BL-05s may be the BL-03 without most of the BL-03's pitfalls like
1. I find it a bit too bassy, even bassier than what I'm personally used to (not just midbass as lots of people would like to claim either, I find it very subbassy too).
2. Mesh is hydrophilic . Although every single IEM I've used suffers from this (yes, every single IEM I had eventually muffles due to caught moisture, the BL-03 was no exception either, or I lend it to my big brother and when he returns it... why is it like completely clogged in earwax? and then I can't remove it because it's stuck to said cloth), it's probably easier to list which ones use non cloth dustproof networks, or otherwise hydrophobic ones. I ripped the mesh out of my BL-03 and made a ring of cotton to put it as a replacement.
3. Looks like a weird cross between an earbud and an IEM which may have made it ideal to wear cable down, but comes with a cable that is only usable over ear (atrocious ear mold at that). This along with the short nozzle makes the fit of this kinda horrible. First time took me almost 3 minutes to get any decent fit. I'm down to about 20 seconds and I'm still improving this time nearly 4 months later. I ordered some Sednaearfits since they're long tips and supposedly able to seal with a shallow insertion and the Zonie so it hopefully doesn't tug the BL-03 out of my ears like stock cable does.
4. I don't own it, but from what I hear it's the ATH-M40x of IEM. Very tonally correct, little micro detailing capabilities as well as non existent imaging capabilities, making both vintage sounding. Soundstage in an IEM is still an alien concept to me so what do I know about IEMs. Right?
Best and also most flawed piece of audio equipment I've put on my ears is probably what I'd like to describe my experience with the BL-03 so far.
Jeez that doesn't sound promising.
Reading your post i realised i was talking about the ATH-M40x not the V-Moda's. Can't stand the M40x's sound.
