Nimweth
And try this on the T2 plus: that drum!
This thread moves too fast for me to keep up with so there has probably been a lot of talk about the T2 Plus already. For anyone who wants to know more, I just published my review. It's an awesome little IEM IMO and a worthy addition to the T-series.
I had been trying in a futile manner to try and upgrade my way up to better bass - right up to the edge of this thread - the $100 TFZ no3 - and all of them sound the same.
Then i tried getting some spinfits for my blon 03 because i couldn't get them to fit - and they make even $10 iem's into bass cannons instantly (tape mods help too). If only I had known this earlier. Hope this is of use to someone else.
I don't like spin fits for their poor comfort. I don't like pressure at all times on my ear. Spiral dots are my go to.Tips can make a huge difference to IEMs, if the seal is anything less than perfect you can wave goodbye to any meaningful bass. I've personally never got on well with Spinfits but I swear by Spiral Dots and Sony Hybrids. I've had some great bass with foam tips, bit I find them too hot for listening for more than half hour at a time.
Yes. I have fitted ML Spiral Dots to my T2 plus. Absolutely fantastic!
To Spiral Dots
And are you sure foam tips sound hot? I hate foam tips because they make the sound warmer and muddier.
I also dont like foam tips, here are my favourite tips (all silicone):Ah no. Not SOUND hot, FEEL hot. Ick.
I have the Mandarin symbio tips (the hybrid, silicone/foam) and dont like it. The foam is too hard and I prefer the sound with silicone rather than foam. (foams help a lot with fit though, but if you have a lot of silicone tips then tip-rolling to find a good fit isnt hard.)I don't much care for Spinfits, the Spiral Dots, Sony Hybrids (and the cheap copies), Starlines and Final Type E are all good though. Not tried the others on your list.
As foams go, Dekoni Bullets aren't bad, and the Mandarines are neat foam filled silicones that aren't the best of either world but an interesting alternative.
I've been known to buy MH750s and 755s just for the tips...
1. Sony Hybrid (EP-EX11)
2. Final Audio Type E
3. Spinfits CP145
4. JVC Spiral dot/++
5. Azla Sedna
6. Acoustune aet08/07
7. KZ Starline
same hereI've been known to buy MH750s and 755s just for the tips...
I've been known to buy MH750s and 755s just for the MH750s and 755s
Absolutely, but when you've already got one of each, getting more for the tips does no harm.
