Nimweth
Next up: CVJ CSN hybrid, (1DD+5BA) coming soon. 1x10mm double magnetic DD, 4x50060 and 1x30095. Sort of ZSX/C12 clone?
Nice write up. Skimmed across and agree pretty much across the board.
Also that offness is the tonal balance. I have these with Sony hybrid tips and a warmish source and they sound sublime. It brings it more in line with the 03's but with better dymanics and a bit more excitement. Also brings some of that texture in the bass and mids which was missing. Still can get hot in the treble though,
I have Sony Hybrid tips too. I'll give it a shot again. I was using Azla Senda Light tips.
I think, with the smoother treble of the starfield, you're going to find foams to deaden the highs a little too much. E Tips, trust me.That is awesome to hear thanks for the breakdown. I am going to order a pair asap.
I will let you know how I go on tips, the Final E Tips look good. Would you recommend foam tips? I enjoyed them a lot on the t3s, unsure if that was just a side-effect of dulling the highs though so perhaps not needed.
That's an exceptional deal but beware that the re400's sound very different from the blons and t2's. You'll find the bass enemic on the re400 coming from what you have. The re400 will sound more clinical / analytical. That said I love them.How good is the deal for new Hifiman RE400 for 26.44 USD (2,000 INR), have the blons and T2's should I go for it.
I know it is from a long time ago, but ... Have you tried them?
Ooh Azla Sedna characteristics is bringing up upper mids and trebles a little with sharp and fast resonance. I wont suggest them with boosted upper mids and bright IEMs. But they are great with sub bass and upper trebles air (soundstage)
I think these will work decently on flights for cancelling engine noise. It does get rid of low frequency noise, but it doesn't seem to perform on the level of APP. I do like these because of being wired with battery life of 20 hrs on a single charge! Flights have high low frequency noise, and these will do nicely. Being wired is important to me given I can plug it into inflight entertainment when I want to. I like such flexability. And another plus, it doesn't have the crappy Xiaomi frequency response.I just pulled the trigger on a wired ANC iems with in-line mic for cheap. It's the Samsung Advanced ANC earphones. Only $15 on Amazon Prime! Totally worth the risk as I like ANC tech (as I find thrm highly practical), and curious how they perform. I'm suspicious they maybe fake since so cheap, but I have doubts they would be with ANC and a battery.
I have Apple AirPods Pro TWS, but wanted a wired ANC set that happens to be in iem format as I hate being on the go with full-sized. The alternative would be Bose QC20, which still goes for whopping $250!
So, definately worth a try at the $15 price.
https://www.samsung.com/us/mobile/m...advanced-anc-earphones--black-eo-ig950bbegus/
As others have said, the RE 400 is bass light, mid-centric. Mids are great - they have a distinctive tuning, and it is really a matter of whether you like that tuning (see Crin's graph). HOWEVER - there are QC issues. Mine split at the strain relief after a few months of light use, and QC seems to be a real problemHow good is the deal for new Hifiman RE400 for 26.44 USD (2,000 INR), have the blons and T2's should I go for it.
