Davidibiza
I think the reason the Symbio Peels work for me is because the surface grips well.
Yep, they work for me as well with my blon, they don't move...
Nah hahaha.
Well, they are pretty balanced sounding for me. It has a decent amount of bass but still loaded with a lot of micro details than all of my single DD IEMs.
Bass is pretty deep and punchy but still in the tight area. The decay and speed is not too slow nor too fast. If you want them to rumble, they can do that too.
In term of zoundstage, they are spacious and airy with good depth & width. I hope i wasn't exaggerating that it almost to the same level as listening to an open back earphone.
The treble is sparkly yet smooth, which is far than the EA3's aggresive treble.
The Mids is still slightly forward from the mix without any mid-bass bleed. Vocal is lush and sweet to me.
Dynamic range, Instruments separation & layering are excellent in this, as I can hear each instrument playing without getting mixed. And last but not least, natural timbre.
I concur with this. I see you have the Faaeal Hibiscus. Try that cable on the BA5, it gives a little more bass depth and a somewhat warmer tonality.I have a quick listen to BA5 yesterday. While the bass do not extend as much as V90, it might be best TRN effort yet.
Fast and quite accurate, timbre is impressive for multi ba, find the vocal enjoyable tough overall imaging is rather intimate and fowards.
Everything is fast and tigh, definition lack some edge but this permit to not be overly agressive.
Bass have good punch, and enough body, not dry, again, fast and tigh.
Mids is where i was the most impress, very informative and good in attack.
Treble, while it lack sparkle, isnt shouty.
(just have a 15min listen so this is to take with grain of salt)
well....this became more and more worrysome. TRN isnt know for top notch QC to say the least. So, your the third for now....
And are you a member or not? lol Your welcome to came in Bro. Chill place. Funny place. No B* place....Non snobbish as well. Similar to here but well...no big Brotha in NBBA!
Edit: okay thanks find the thread....well well....even more intriguing!
https://www.head-fi.org/threads/urbanfun-ybf-iss014-lost-potential-for-greatness.921709/
Uh-oh! I didn't know there was a balanced version! I might have to try that.This is my exact set up, and I concur with this concurrence.
Bass sounds more expansive for me as well, for sure, in an ethereal rather than boomy way.
I like the combo so much I've ordered the balanced version
Sure, your welcome.WOW.
Well, now i'm supremely excited to try them. Might be the BLON upgrade were waiting for.
Thanks for sharing more toughs.
The Blons? Have you tried them cable down? I have a shallow but stable fit wearing them up or down using Symbio Peel tips... the shell body rests firmly in the concha area. I do not use longer tips or extenders because then they would move around for me.
Cable down is awesome with the Blons. Solves pretty much all of the fitment issues. It only needs a 3rd party straight cable (or remove the ear guide cable off of a 3rd party cable to make it hang straight).
It doesn’t work with the stock cable though, as the stock cable has an angled connector.
So, I could finally get around to reviewing the Sennheiser IE 40 Pros. I've been using them on an off for the past couple of months, and they seem to be a great option in the sub-$100 range. Never thought I'd be recommending a budget Sennheiser IEM but they indeed deserve that. Natural timbre and a smooth mid-to-treble transition that's perfectly suited for long listening sessions. I guess some will mind the mid-bass boost, but I think that is essential for the intended use case. Have a read here: https://www.head-fi.org/showcase/review/23138/
Well....you love the Spacesh*p...so thats sure a no go for me. Among worst sub 30$ iem i heard.
I see you have HD650 on your list.... do you have any recommendation for budget ciem that has the same sound signature ?I don't like the Spaceship, per se. I haven't even reviewed them yet. It was just first impressions and since then they've been in the drawer. :/
I do love the Moondrop Crescent though, and BLON, and our mutual (!) love Final E5000, so there's that.
