There is is no sound leakage from these "vent holes", it's fake semi open design as on the ****.
Well that clears it up by a whole lot, I read that there is slight bass leakage. Okay so, in this case I will keep the V90 in my consideration.
f you want extreme isolation, then look at the KZ ZS3E or ZS4
I am not looking for extreme isolation, my main concern is sound leakage. I am already having a hard time with deciding between TRN V90, BQEYZ K1, and the LZ Z05A. I am aware that buying even both of those could be a plus, but since I am already convinced that these higher budget options are way better, I'll let it be. Either way I only have two more days to make a firm decision.
I will leave out the TinAudio T2 since it would reach my budget top and doesn't seem to be a crazy competitor to other choices, they definitely sound like a great option, but as I am in a conflict it's easier to leave them out. Which may be the wrong option, but hey.
almost vinyl sounding IEM appeals you will love it like you would love no other
I am not sure how vinyl like is, weirdly enough as we live in the digital era, and especially me not having enough money to invest in vinyls, I primarily listen to digital audio, either from spotify or high quality download.
I will leave out the amazing Blon BL03 since they seem to be a love/hate IEM. They are preferred with an amp. It would also consume time to find the perfect fit, so at this time I'll have to pass on these greats. It truly feels bitter to avoid them at 20 USD....
The KB06's are also not in consideration due to their sound leakage.
The ****'s, also not my cup of tea at the moment.
CCA C12's seem pretty impressive, but would I compromise the comfort for sound quality (no major differences)? I doub't it, and it is possibly that I have interpreted it all wrong, it was said that they aren't as comfortable as the V90's.. but again doesn't mean they are uncomfortable.
I do not listen to jazz, punk, metal etc. Ocasionally I will listen to rock and hard rock, but that is like maybe twice in two/three months. Main music is kind of dark r&b with soul like vocals, dreamy and cinematic like, but mid's are definitely something which I don't mind being compromised. Modern rap and trap are on my heavy rotation as well.
Stretching a bit the budget could also be worth considering maybe, in the end it's often better to get 1 great set than 3 meh ones
I am aware of this, but being in the financial situation that I am I am aware that I have much wiser things to spend money on. I know that I will need to buy a bunch of audio equipment for audio production, so the pennies will be much more needed in that section, which is definitely primary. I just want to treat both myself and my ears with something which will be noticeably different than those stock earphones from phones.
Good point. Many of us have spent thousands and thousands of dollars chasing that ‘perfect’ earphone. It doesn’t exist.
True, we are in the endless search for perfect. I know what you mean by that.
So all my picks seem to be easy-drive: (prices with a coupon)
TRN V90 (~25 USD )- very pleasant sounding, even said more energetic than Hibiscus. Pleasant to the ear. That "V-shape sound signature" stamp in reviews gives it a bad look for me
LZ Z05A (~22 USD )- seems like a great option, from a very well respected brand. My problems are the noticeable lack of info about them, and the cable is turning off.
BQEYZ K1 (~19 USD)- also lack in info due to the wireless one being mainly reviewed, and I don't have a clear comparison for that reason. The closest I got to comparison is that it's better than the BGVP DNS1. It was also called the "new K100 with bluetooth cable" which certainly isn't correct and helpful. It was also labelled as a V shape sound signature, but didn't receive as much positivity and attention as the V90. Also clearly stated that it is fatigue-free.
for reference:
BLON BL03 (20 USD)
CCA C12 (~25 USD)
For your budget, I'll second the recommendation for the BLON BL-03. The sound coming out of those things is terrific. It's not the most bassy, or analytical, or what have you; but it's one of the more enjoyable, if that makes sense.
It's hard to get a good fit/seal depending on your ears, the stock tips are awful, and some people have had problems with the stock cable (it seems to depend on the batch), so it may be too much of a gamble for you.
This is what I meant. Some people get an amazing fit with stock tips, for some the cable is good. Overall not the most stable. It feels rough passing them, but I'm running out of time and I'm clearly trying to narrow my search.
