because I've heard the stock cables may fall apart.
I selected it because it is reputed to be a 'balanced' cable, and 'balanced' copper/silver apparently does well with the CNT-1. Or should I get something else?
I don't know about the new TRN cables but the old ones were not soldered correctly. For that reason alone I personally would not do business with them anymore. If the new ones are fixed then they need to send me 5 new fixed ones free of charge, since I bought 5 of the bad ones.
I personally use NiceHCK 8 core cables on mine. They have copper and SPC versions and I believe they are selling at $7-$8 each. You can also get them in 2.5 balanced and 4.4 balanced or 3.5 SE. Good cables and they measure really low resistance.
Balanced in this case refers to the plug termination. If you are using a balanced source you would choose the 2.5mm or 4.4mm option. If your source has normal 3.5mm output then choose that.
I have the nicehck silver cables both balanced and single ended. They both make the treble even harsher as they are more transparent than the stock cable.
TRN V60 Pro
Depending on your favored genres, the vocals will be spot on, to forward. I find Pandora's Pink Floyd radio to be a perfect match for the TRNs, but early 2000s Hip Hop to be a little on the bright side.
If you have an EQ, you can dial them in.
Don't buy it from Amazon. The vendor that pops up is selling the non Pro, with the product description for the Pro.
The story goes that TRN's subcontractor for their eight core cables botched the terminations. I believe it was @Slater that verified the 16 core, to be good.
TRN V60 Pro
While front vents to make the bass lean (as it bleeds off pressure), I’m not sure about the 2nd vent hole.
The promotion material says that the 2nd vent hole is a “weatherproof hole”, used to “prevent diaphragm distortions due to temperature changes”. Whatever the hell that means.
I’ve never heard of that in my life. Who knows what effect it will have on the sound (if any).
Hi Slater,
the 'weather proof hole' protects IEM diaphragm against distortions by too much temperature difference between outside air and ear canal during the winter season. Actually, it is not just a hole but a kind of structure to prevent distortions while maintaining sound quality.
Wow I also didn't realize they had different driver count between the 2. Some of the Aliexpress shops also don't really state properly whether they are selling the Pro version or the normal version.
I mean IMHO tuning trumps driver count any day, but kinda strange that the so called Pro version has lesser drivers LOL.
I think that was an error on the non Pro packaging. If you look at the Chinese it shows 2+1. I think they both have a 10mm and 3.8mm dynamic plus 1 BA. All the old reviews indicate 2 + 1.
