They're just out... my finger is on and off the Add To Basket button on Amazon lol. 100 bucks ain't cheap... I've a feeling they'll either really surprise me and sound great or sound average and over priced. BIG step up from their budget friendly range... the QT5 offering superb value for money. I'd expect a big leap in sound.
I've an 1h 45m left to buy to get tomo.
What to do?!?!
EDIT : Bugger it, good bit cheaper from Alie but i'm too impatient so bought thru Am UK. They come tomorrow, time will tell if they've upped their game further! They look awesome, interested if the vents are just for aesthetics?
it appears to be very good BLON BL-03 is 90% with some eq settings like moondrop kxxs according some user from aliexpress .. he says its tuned by the same guys of tanchjim oxygen ... i think its a iem to watch out for...
WOW, that's some comparison... are they that good? As per usual i'm late to the party on these lol. Not by any means a good looking earphone though... but I've got plenty other ugly ducklings that sound good.
This is my first post on here in months. Fell away from the hobby for a few months but got suckered in by the BLON and the Semkarch CNT 1. A carbon nanotube double!
Anyway they've both ignited the touchpaper again for me.
Don't want to say much until I've had then a bit longer but agree with neutral to bright description for the BLON.
This is after changing the tips to wide bore foams as it was nigh on impossible for me to get a seal with the stock tips due to the design.
Just got the Semkarch today and REALLY like them on m first listen too.
I'm of the impression that IEMs with piezo drivers generally need a fair amount of amping to truly shine for the treble. Is the NX7 drivable from a phone? Or it needs amping?
My Hyla TE5B with a piezoelectric were driven fine by iPhone 6 SE (half volume). They are driven at least as well by the FiiO Q5 (half volume, low gain); however, a good piezoelectric can shine without much help - and I make no claim that the Q5 makes the piezoelectric / treble sound better as I would quite probably fail a DBT.
In the NX7 case, I’d imagine it’s the 2 “nano tube” DDs driving up the resistance - not the piezoelectric.
I think pretty much all mainstream IEMs are drivable by phones and other ‘lower power’ AMPs - even if NiceHCK may claim otherwise. YMMV per listening levels.
(NX7 is rated at 55ohms and 108dB sensitivity, which is not that ‘challenging’; TE5B is 12ohms and 97dB.)
My Hyla TE5B with a piezoelectric were driven fine by iPhone 6 SE (half volume). They are driven at least as well by the FiiO Q5 (half volume, low gain); however, a good piezoelectric can shine without much help - and I make no claim that the Q5 makes the piezoelectric / treble sound better and I would quite probably fail a DBT.
Great advise.
I always used to look at sensitivity and resistance when deciding if an amp was needed, but I realized for the ****, which has piezo drivers for the treble, it took more juice to make the treble sound good. I had to boost my volume to almost 70% on a samsung smart phone (without Amping), compared to like 30 - 40% for other BA driver IEMs. (I'm no physics expert, but **** specifications are apparently 32Ω with a sensitivity of 110dB/mw, so I was wondering why there was a discrepancy between the specs and drivability and attributed it to the piezo drivers).
Semkarch for me as you get 2 tuning filters and case. They are also more resolving and have a heftier low end which I prefer. Add to that the fit issues of the BLON which are practically non existent with the Semkarch and it's a clear win IMO.
Keep in mind that they also retailed at a much higher price initially. I know that doesn't automatically denote a better quality product, but it "usually" does.
I would snap up a pair before they're all gone because at £25 / $30 they are an absolute steal!
All three pairs of my KZ IEMs have broken down with 3 months of being taken in to use, one pair broke within a week. All from the cable connection point at the point of the IEM (not the cable).
I will never buy another KZ IEM until they make them sturdy and reliable (as a comparison, my Westones lasted 3 years until lost and my Shure SE series only broke after I repeatedly stepped on them by accident).
Haha I had the opposite experience for myself personally.
My 2 Westone products I bought (Westone 3 and Westone W30) both had problems with the cable within 1 year of purchase. And I was quite peeved cause the Westone 3 cable was non detachable and hence there was no sound from one earpiece, while at least the W30 had a possibility to use another cable as it was detachable. It seemed the cable part that connected into the IEM was frayed for both. I only used them once a week for stage monitoring and otherwise kept them in a pelican case, so I'm not sure how come they had such wear and tear within a short period of time. But yeah the IEM shells and drivers themselves were fine, so it was more of a cable problem.
On the other hand I used my KZ ZS6 and ZS10 (non pro) daily for 2 and 1.5 years (respectively) and they were still going strong until I gave them away to some relatives last week.
Maybe i had good luck with getting a pair that had no QC issues. But it is very possible some of the budget CHIFI companies may not have consistent QC across their products, as evident from some of the feedback in the forums. Stuff like channel imbalance, phase issues, fake wirings in cables etc, so getting a lemon is always a possibility, and it really may be down to good or bad luck.
Great advise.
I wish it was possible for me! Yesterday I discovered the cause of my dissatisfaction with ****. I don't have a calibrated mic, but I can still see where the error is when I compare it to T2. The peak around 4 kHz does not allow me to add more juice and causing a strange fake soundstage FR graph is the same for left and right, so it looks like some bad batch of used DD and poor QC. And yes, if I adjust the peak with EQ, I need to add volume, but I'm still not much happy with the sound. https://i.postimg.cc/PvQG5N9p/****-vs-T2.png
