Hi! I own ZS6, BQ3, AS10 and C10 which I love most for it's deep sub bass and balanced signature. Now I'm thinking to try Auglamour F300. Would it be an upgrade over C10 for a basshead guy?
No.Hi! I own ZS6, BQ3, AS10 and C10 which I love most for it's deep sub bass and balanced signature. Now I'm thinking to try Auglamour F300. Would it be an upgrade over C10 for a basshead guy?
I think your BQ3, AS10, C10, ZS6 all aof them are superior than F300. Definitely wont be an upgrade. Your upgrade will be on $100 above..
For Basshead and balanced signature you need NiceHCK EP10. $15 and sounds great. Bass will rattle your teeth. I have EQ'd them to +20 DB at 30-60hz and pushed 60% of an 800mw amp into them and they took it like a champ. My teeth rattled and I couldn't see because my head was shaking too hard.Hi! I own ZS6, BQ3, AS10 and C10 which I love most for it's deep sub bass and balanced signature. Now I'm thinking to try Auglamour F300. Would it be an upgrade over C10 for a basshead guy?
Unfortunately I need iems equipped with a 2-pin connector so I can use my Bluetooth module.For Basshead and balanced signature you need NiceHCK EP10. $15 and sounds great. Bass will rattle your teeth. I have EQ'd them to +20 DB at 30-60hz and pushed 60% of an 800mw amp into them and they took it like a champ. My teeth rattled and I couldn't see because my head was shaking too hard.
Oh, I totally forgot aboout this regarding KPE 12kHz "peak". You see how that "peak" has GONE AWAY with some "burn-in" ! That`s probably why I don`t hear it!
End of "arguing" about that "peak"
What about C16? AS10 is the only no-DD iem I have and I like it's SS except subbass which roll off pretty fast comparing to C10.
The C16 is a clear step-up over the AS10. More clarity, better soundstage and instrument separation, stronger and deeper bass, more detail. The AS10 is warmer and darker sounding , instruments have nice texture, it is lighter and more comfortable (the C16 is relatively heavy and can work itself out of your ears a bit). The AS10 is not bad sounding by any means and probably better suited for longer listening sessions. EDIT: Actually listening to some classical music on them right now for testing, I don't feel like taking them out of my ears.
Take a look at different measurements from different ppl - some don`t have such strong peak at all and some have it only one channel.
The peak on my pair decided to stay , also on all Android measurements the peak is there
if you read the text next to the measurements (before and after burn in) he removed them once and put them back latter
agree, on the German site there is no narrow peak in the upper treble too, maybe i didn't run them enough, however i dont mind it, i kind of like itTake a look at different measurements from different ppl - some don`t have such strong peak at all
How about C16 vs C10?
Neither of them are basshead.How about C16 vs C10?
