el_matt0
- Feb 7, 2007
you need asio4all to run an av710?
Originally Posted by el_matt0 /img/forum/go_quote.gif you need asio4all to run an av710? |
Originally Posted by sugarinthegourd /img/forum/go_quote.gif Any ideas on why Envy24 is showing up as unavailable? Does it matter if I select AC97 instead? |
Originally Posted by lim(x->0) /img/forum/go_quote.gif 1) 2) Which setup would be the best? av710 >> black jack next to optical out >> 2CH Hi-Sample Rate >> foobar >> KERNEL stream >> 96k Hz |
Originally Posted by sugarinthegourd /img/forum/go_quote.gif Your ordering of processes is a bit mixed up, I think. Don't you mean something more like: foobar >> 96 kHz resampler >> KERNEL stream >> av710 >> 2CH Hi-Sample Rate >> black jack next to optical out |
Originally Posted by event /img/forum/go_quote.gif ONE: No sound from the rear surround jack, I had to use the green line out jack. |
Originally Posted by lim(x->0) /img/forum/go_quote.gif 1) Is there an advantage in using, 2CH Hi-Sample Rate >> KS >> 96k Hz, over the setup posted originally in the guide or is the setup in the original guide better? 2) Which setup would be the best? foobar >> 96 kHz resampler >> KERNEL stream >> av710 >> 2CH Hi-Sample Rate >> black jack next to optical out or foobar >> 96 kHz resampler >> DIRECT stream >> av710 >> 2CH Hi-Sample Rate >> black jack next to optical out or the config posted by infinitessymphony in the guide: foobar >> 48 kHz resampler >> KERNEL stream >> av710 >> 2CH >> black jack next to optical out 3) Should I be using the foobar equalizer or just leave it flat? |
Originally Posted by infinitesymphony /img/forum/go_quote.gif 2. IMO, the third choice, except that the guide does not say to resample. The idea is not to resample. |
Originally Posted by lim(x->0) /img/forum/go_quote.gif I got the resampling tid bit from this setup guide which is also on the first page of this subforum along with this one. http://www.head-fi.org/forums/showthread.php?t=248641 |
Originally Posted by bilboda /img/forum/go_quote.gif So, after reading thru the thread, I see you like the EMU products. Would a 0202 usb be much of an upgrade, iyho? |
