infinitesymphony
- May 15, 2006
Yes, that's the infamous "jumper mod" thread.
As other people have said, this "mod" doesn't affect the Wolfson DAC output, and it's not even confirmed whether or not it's a desirable mod for the front channels. Note that this guy's equipment was limited to a pair of DIY modified Sennheiser HD-280s running out of a DIY CMoy amplifier described as "crappy."
There are no settings that you can change to bypass the mixer in the same way that KS and ASIO do, besides looking for plug-ins for the particular program. Bypassing the mixer with KS or ASIO is ideal, but just using DirectSound isn't so much worse (depending on your equipment and ability to hear differences). With a 2.1 computer speaker system, the difference probably won't be huge.
Basically, use audio programs for audio; there's no need to worry about specialized routing for everything else.
...So, find JP3/4. Go over to the right about an inch, to the jumper bank labelled Front Audio. Now go down, and you'll see a chip marked U14. Directly below this are the jumpers in question...Now, these results have not been verified, but I thought there was increased bass, for one, and an overall tightening of the sound with this tweak. |
Originally Posted by gozu /img/forum/go_quote.gif What about other applications that are not ASIO compatible? Media Player Classic and so forth? Do I change the settings for those? |
