ryder78
- Dec 20, 2010
Guys, for those who have the RU7 presumably connected to the phone, do you listen to the device with or without EQ? If with EQ what is the app that you use to adjust the EQ?
The reason of the question is I found the KA15 with user-adjustable PEQ via FIIO's app to consistently sound better than the RU7 (with EQ applied using the Wavelet app). Without any EQ, the KA15 sounds very ordinary or unspectacular. Ditto the RU7. The PEQ makes a big difference to the overall sound presentation of the KA15.
