Hyde00
Was looking at Mojo for a long time too until this come along.Cayin Ru6 or Chord Mojo?
Damn that's impressive. Which might work better since I don't want to deal with Mojo's battery actually.
RU6 is better. Mojo sounds DSP and processed.Was looking at Mojo for a long time too until this come along.
It depends on what you are pairing it with. If you need a warmer presentation and/or power, then Mojo is it. If you want a more natural presentation, then RU6. Both are good.Cayin Ru6 or Chord Mojo?
You would expect posts like this in the RU6 thread. If the question was posted in the Mojo thread, you would get the opposite.RU6 is better. Mojo sounds DSP and processed.
Thanks FriendIt depends on what you are pairing it with. If you need a warmer presentation and/or power, then Mojo is it. If you want a more natural presentation, then RU6. Both are good.
I'm using the RU6 with my Surface Go without any driver installed. It works right out of the box and I don't feel like I'm missing anything (I'm using direct audio though. ASIO and WASAPI don't work. I think you need to install driver to use those)What about for Windows? I think their product page says Windows OS need to download a driver made for RU6 from official website.
Or is it one of those if you want to go higher than certain sampling rate, otherwise plug and play?
There are options without built in DAC's. It's just the form factor which most are looking for always comes with a built in DAC. It is true that some of those built in DAC's have a pass though mode but depends on the DAC chip and I just prefer to get that out of the signal chain so I suggest using a USB C splitter which splits to USB C for PD and USB A for data. This type doesn't have a DAC built in as they are intended for use with other periferals and then if you use a small USB A to USB C adapter you are good to go.After reading all 84 pages may I conclude we haven't found an Android USB-C charger/splitter that has 5V output power without adding DAC nonsense, that allows us to charge the phone wired while simultaneously using the RU6?
That's more than a bit annoying to be honest; not even because of the reading hours involved. It pretty much makes long listening sessions impossible
drftr
Stay updated on Cayin at their sponsor profile on Head-Fi.
Such as thses splitters:
https://smile.amazon.com/dp/B0968Q7...abc_QVMCSSPVCTRQNFAHJC63?_encoding=UTF8&psc=1
https://smile.amazon.com/dp/B08C5FW...abc_JJ36YRMM9XB6QKXX9D9B?_encoding=UTF8&psc=1
Such as this USB A to USB C adapter
https://smile.amazon.com/dp/B072M9L...abc_R7CSYKPSQ2D7FT50WCTT?_encoding=UTF8&psc=1
It is confusing for sure.I couldn't understand these built-in DAC options. So you need a purely analogue USB-C terminated headphone in order to use the DAC in the splitter? I didn't see USB-C with analogue signal in the official USB-C pinout.
If you look at any usb c splitter which goes to two usb c connections it is designed to meet the need to using usb c earbuds and usb c charging. Since at the beginning when phone manufacturers were getting rid of the 3.5mm jack there were some analog usb c earbuds these splitters come with built in DAC's so those will be compatible as well (rather than face mixed reviews). Therefore, yes one would need to have analog usb c earbuds to use the built in DAC. However, most modern day usb c earbuds have built in DAC's and thus there is supposed to be a built it pass through mode where usb c data is passed though directly to the DAC built into usb c earbuds rather than the DAC in the splitter. As for the pin outs, I have not seen any for these types of splitters. But analog usb c earbuds use the following usb c pins: Left Channel > D- (A7) ; Right Channel > D+ (A6) ; Ground > GND (A1).
Now the splitters which I linked have one side with female usb a. These do not have a DAC built in and the data transmitted from the phone is not tampered with. The usb c side of the splitter just provides power to the phone while data is routed through the usb a.
I'm considering buying the RU6 but since I'm new to the concept I'm currently reading the whole thread. Being just over halfway I have 2 questions that I'd like to see answered without another day of reading as I'm getting excited! I'd appreciate it if anyone could help on these questions:
1. Being permanently travelling I won't have access to a computer. Can firmware be installed using my Android phone or do I need a computer for that? In fact, can I even use it straight out of the box not having a computer for initial setup?
2. I'm using the PowerAmp app and I'm very happy with it from a usability point of view, but I do know UAPP sounds a bit better. Will the RU6 avoid the upsampling that PowerAmp uses and take the signal straight from Android? That would be a win-win for me. Or will it get the upsampled PowerAmp signal instead, rendering NOS pretty much useless?
Tnx much...
drftr
Neutron, Uapp, Onkyo HF, Maiden audio... are some of group 1.
Jetaudio, VLC, Power amp ... and tons of app are in group2.
Idk what's "direct" in your post but seems you must change your player app to some in group1, a group that bypass Android audio stack.
For ex. if you plug a ext dac into usb port, Uapp or NeutronMp pop up to ask the right of controlling. Since then (after click Yez) you found all system audio effect such as EQ, DSP are no longer affect/altering the output audio.
Ofcouse EQ, DSP OF THE APP is available, when you need it
Yeah, I was afraid of that. Tnx for confirming though. Guess it's time to dig up my list with points why I selected PowerAmp over UAPP among others. Would be a pity as I fell in love with its setup, interface, etcetera, but such is life...PowerAmp does not support bit-perfect USB Audio output, so all playback from PowerAmp will go through the SRC (Sample Rate Conversion) in your Android mobile phone. The output is pleasant and enjoyable, but since the RU6 has a oversampling routine to convert all PCM signal to 24Bit/384kHz, you have gone through TWO layers of oversampling if you are using OS mode of RU6 because of that.
Do you also have one in mind with 2 USB-C outputs instead of one being USB-A (and without DAC)? I would use it with a PD charger. I just had a look at Ugreen and DDhifi among others and then came across this Belkin splitter. It's more expensive but comes with 2 year warranty and having had some of their products in the past I have a bit more faith in them than in nameless Chifi brands to be honest. Do you think this would work:There are options without built in DAC's. It's just the form factor which most are looking for always comes with a built in DAC. It is true that some of those built in DAC's have a pass though mode but depends on the DAC chip and I just prefer to get that out of the signal chain so I suggest using a USB C splitter which splits to USB C for PD and USB A for data. This type doesn't have a DAC built in as they are intended for use with other periferals and then if you use a small USB A to USB C adapter you are good to go.
