- Oct 6, 2013
I'll 2nd that, OE Audio usb otg cables have one of the best build quality, very well engineered IC.I bought USB cables from here on recommendations from others. Works like a charm and very well built.
… and, according to their website, they have a couple of distributors around the world. Even in a sort of ”under-developed“ HiFi country like Germany.I'll 2nd that, OE Audio usb otg cables have one of the best build quality, very well engineered IC.
Where does one acquire a replacement adhesive magnet disc? I had two that came with my orange RU6 case and put one on my iPad and one on my iPhone. Inserting and removing my phone from its case wore the leatherette off of the magnet.
Stay updated on Cayin at their sponsor profile on Head-Fi.
I'll have to check those outI bought USB cables from here on recommendations from others. Works like a charm and very well built.
I have both the W2-131 and RU6 here and both are great. There's a difference in their sound, obviously, but I wouldn't describe the differences so dramatically. I suppose that the R2R NOS sound was more of a big deal for him than it is others.out of the 100+ dongles andy has rated, the RU6 is #2 overall. the W2 is not even in the top 10.
out of all the dongles i would buy, the OG W2 would be the other one i would check out. i would still like to hear one and compare to the RU6.I have both the W2-131 and RU6 here and both are great. There's a difference in their sound, obviously, but I wouldn't describe the differences so dramatically. I suppose that the R2R NOS sound was more of a big deal for him than it is others.
Have you tried using some other phone with the RU6? If you still get EMI then maybe you have a faulty unit. I've experienced severe EMI with EarMen Sparrow and to some extent with Mojo but not with RU6. I'm using stock USB Cable with mine.The dreaded EMI noise problem is still not solved even with my new FiiO shielded cable. It is less prominent though. But when carrying the RU6 and my phone in the same pocket, it will inevitably happen.
The RU6 shielding if it exists at all is really really bad.
This is still one of the best sounding dongle DACs in the World but if I had to review it now, I would give it 4 stars out of 5, because it cannot be used as intended with a phone on the go.
I will still try to get the leather case and DIY a shielding layer with aluminum foil inside of it, but there is no guarantee it will work
Ahahah i ordered fiio cable. I have noise not in my pocket but when move in my house. I don' t know if happens when phone disconnect from wifiThe dreaded EMI noise problem is still not solved even with my new FiiO shielded cable. It is less prominent though. But when carrying the RU6 and my phone in the same pocket, it will inevitably happen.
Awaiting your thoughts, though usually i don't believe in cable =)I bought one. I'll try this weekend
Me too. Tried the cable. Nothing new. Now ordered fiio cableAwaiting your thoughts, though usually i don't believe in cable =)
