- Nov 16, 2013
No.
He Andy did not say any thing close to your expressed.
He said Ru6 adjust volume output at analog stage. It means resistor to adjust volume will not do the "dac" function.
I can put an example. When you click + once, a resistor join the audio path.
To not requires upto 100 resistors, they are in array/matrix.
Those array, imo, lay somewhere between amplifier chip and R2R matrix (this matrix do digital-analog conversion) and doesn't need high accuracy.
Guess that you want vol 70 is 66dB but by inaccurate value, become 66.6dB is not ideal but affect nothing!!
R2R matrix do need high accuracy. Analog signal get from them is somewhat 0~2V (0.0006V each step theoretical) so if those resistor error 1% the output is not presice for music.
In short: R2R matrix works natively and independent from physiscal button on Ru6. It's resitor is not the one which use for volume adjustment
Thank you for clearing the doubt. For the record, there are two sets of resistor networks in RU6, One set is the 24Bit Discrete R-2R Resistor Ladder DAC that composed of 96 pieces of high precision low TCR Thin Film Resistors rated at ±0.1% (or 1/1,000) and TCR25 (±25 ppm/℃), the second one is the Resistor Array Volume Control. The cost and complexity of building the discrete DAC and discrete Volume control far exceed the cost of buying those off-the-shelf highly integrated multi-function "programmable" DAC chipsets. We understand a lot of users are so used to the convenience and flexibility of the highly integrated DAC solutions, that discrete DAC approaches such as RU6/RU7 become a very niche market and they are not necessarily good for everyone. We got that, that's why we tried our best to explain the constraints and limitations of our product on the first page of this thread and on the RU6 product page of the Cayin website. We try to steer users away as early as possible if this is not the right product for them.
Stay updated on Cayin at their sponsor profile on Head-Fi.
