Thank you for your clarification. May I invite you to check out my explanation of N8ii tube amplificaiton design at the opening post of this thread or HERE?
We used three different circuit design to implement N8, C9 and N8ii. If "being tubey" is the only criteria, then N8ii will be the lowest rated candidate in the trio. If you expect "n8ii to sound closer to the tube mode on the n8", you can cross out N8ii from your wish list, unfortunately.
We have tried our best to explain our design phillosophy. The expalnation was thorougly explained in the product announcement livestream in Chinese, and I have posted the English version rougly three hours later here in HeadFi forum (both on opening post and on-going discussion).
We never use the term neutrual reference to descrbe the sound characteristic of our product because the term actually means totally different things to different poeple. Likewise, warm is a relative perception because we don't have a standard to mearsure "cold" or "warm" in audio performance. For example, if you are a Chord DAC users, N8ii tube mode is warm. If you are use N8 tube mode as reference, N8ii is cold.
I think my response to hshock76 will also answer your question. We have carefully fine tune the negative feedback loop in order to achieve the transparent, crispy and transient we are targeted at, so Nutube is definitely emplyed as one of the amplification stage, instead of using it as a buffer stage of DAC or amplification circuit. For the same reason, "Nutube is not in the loop for line out because nutubes are function as an amplification stage, it is not a buffer or dirver stage, so we can include Nutube in the Line out." (HERE)
If you look at the functional diagram of N8ii (HERE), you'll notice that the Nutube are immediately behind LPF and SE/BAL conversion, I'll call this FIRST stage of amplication if we need to concern about the sequence.
Do you mind explaining to us on what is the purpose of using nutubes / what do they bring to the N8ii amplification stage?
Since tubes are usually introduced to bring the tube-ish flavour into the sound, however since that is not the purpose of the nutubes in the N8ii, won’t you be able to get your end sound with just the SS amplification?
