bluestorm1992
Also, I am sure you see the positioning challenge here. If ppl say N8ii is great or even better than C9 (when paired with a decent dap), then some ppl will say what’s the point of owning C9, I will just go with N8ii! Much more convenient as an all-in-one anyway.Hope you are kidding about C9.. C9 uses 4 seperate batteries for amplification (it is a pure amplifier.. purity at its best)... A DAP that uses Lithium ion battery (3.7 V, 10000 mAh) to power everything including software, internal electronics and amplifier is not going to compete against pure amplifier.. N8ii is great for portability and first of a kind to have dual KORG tubes (technology inherited from C9).. Also, all the Class A/AB (Cayin N6ii) and solid state/tube (Cayin N8) stuff have been inherited from previous Cayin DAPs.. I am sure @Andykong would not put Cayin C9's amplifier's capability under N8ii (that is like throwing your own exceptional product under the bus)..
On the other hand, when some other ppl conclude that C9 is still much better, then ppl will say: oh N8ii is not worth it since C9 + a decent dap is likely to be even cheaper.
Clearly, a more objective and comprehensive view for C9 vs. N8ii will depend on the user’s own use case. For people prioritizing simplicity, N8ii will be the way to go. For ppl prioritizing Sq and versatility (using both iems and hps, wanting to roll the source dap), C9 will be the way to go. However, such narration gets very complicated and detailed. Honestly, a lot of times I don’t even understand my own preferences well enough. We may expect to see them here a lot when N8ii actually launches.
