Somebody using Roon Arc on the N8ii?
I am broadening my use cases in the ever growing world of networked audio, doing this for fun, for gaining experience and ultimately for maybe developing useful ways to enjoy my music.
Having Roon on my laptop running as a core, I ventured into using Roon Arc on mobile / portable devices. Very easy to set up the Roon Core and the home WiFi router as well as Roon Arc; Roon Arc is transparent in that it displays the signal path in detail at every step.
My findings until now are as follows. Currently, I tested PCM audio tracks only, but occasionally also looked into DSD. You will see why I am posting on the N8ii thread near the end (cf. Part B).
Part A: Very nice concept with an iPhone, and working fully as expected / hoped for. In my examples, Roon Arc on the iPhone plays bit-perfect with a USB-DAC hooked up to the Lightning port, i.e.
1.) Cayin RU6 via the Cayin-supplied Lightning-to-USB-C cable;
2.) Chord Hugo 2 via the Apple Camera Adapter (which is nothing but a USB port attached to the iPhone) going into the Hugo 2 USB input;
- as a side note, notice that the Hugo 2 provides a great way to circumvent the restrictions on USB power drawn by separating digital data input and 5 V power input into two USB ports;
3.) Cayin Nn8ii in USB-DAC mode via the Apple Camera Adapter going into the N8ii USB-C input;
- as a side note here, notice that this works only with the Apple
Lightning to USB 3 Camera Adapter when it is separately powered by a wall wart because the N8ii alone gets rejected by the iPhone as drawing too much power; however, this tying the iPhone to the wall wart kills portability.
Summary for my iPhone running Roon Arc: Great!
Part B: Next step, check into Roon Arc running on the N8ii, with an IEM on its phone out. This works, but with a BIG gotcha: Everything gets downsampled / converted to 44.1 kHz - indeed, nothing shows up as Bit-Perfect Lossless, just as High Quality (not even 16/44.1), as every audio gets shoved out via AAudio. The enclosed six pics illustrate these findings.
This behavior of Roon Arc on a Cayin DAP had already been noted e.g. with the N7, cf. this post by
@Currawong:
Arc won‘t output bit-perfect on the N7 for me.
For me, there are two possibilities:
(a) The Roon Arc Playback Engine isn‘t fit for Android yet;
(b) I am not sure whether Roon Readiness would play a role here, since as of now I think Roon Readiness means the device is capable of working as a Roon endpoint linked to the Roon Core via WiFi.
Summary for my N8ii running Roon Arc: In either case (a) or (b), the promise that the N8ii or actually every DAP with HiBy‘s Android DTA should provide bit-perfectness for
any app running on such an operating system just doesn‘t hold yet for Roon Arc. Whoever (Roon? Cayin/HiBy???) needs to work on this …
Thanks for your endurance reading this - FWIW …
