Hi @Andykong,
Ibasso managed to put Android 11 on the same SOC and same RAM than N8II (snapdragon 660 / 6go RAM) on their DX320.
What are the technical constraints, if any, on doing the same thing on the Cayin N8II ?
Maybe this is a choice, and you could explain us the reason of this choice ?
Thanks,
If we were to develop a new DAP with Snapdragon 660 now, then we definitely would go for Android 11.
We finalized the N8ii solution in late 2019, and developed a working sample with AK4499EQ by Q3 2020 (that's why we ordered a bulk order of AK4499EQ that was used in N30LE). The AKM fire (October 2020) forced us to change the N8ii to RoHM DAC and delayed the launch till mid-2021. So we are talking about a decision we made all the way back in 2019.
I can't speak for other brands, but we did the following during the R&D process of our DAP products:
- Select system platform (MCU + Android kernel, playback engine)
- Select a digital audio platform (DAC, and IV if needed)
- Formulate FPGA (the bridge between MCU and DAC, and the DTA that bypasses the Android SRC)
- Design and optimize the analog sound system (Dual Timbre, Headphone Amp, and Line drivers for LO/Pre Out in N8ii)
Can we upgrade N8ii to a newer Android platform? Yes, technically we can do that and the process is actually fairly straightforward when Snapdragon can provide the upgrade patches. However, we'll have to live without a properly tuned FPGA, losing the DTA, and affecting the performance of the DAC. The analog circuit is based on the IV output (which is equivalent to the output stage of the DAC), so if the IV output is altered, the analog circuit is not fully optimized after the Android upgrade.
If we happened to have more Snapdragon 660-based DAP projects in 2021-2022, we probably will have a 660-based DTA solution for Android 10 or Android 11, unfortunately, we don't have that, we switched to Snapdragon 665 (and an updated HiBy playback engine), the newer the FPGA solution is not applicable to N8ii.
Stay updated on Cayin at their sponsor profile on Head-Fi.
