So this is a new amp from China ? SE and output transformer less. That tube is line buffer ? Or is it output stage ? What voltage rails is it running ? I don’t see much of it from googles and I can’t read much either. It look great though, but the KAEI TAP1 is also an excellent choices as it can act as desktop tier in technical term. However a real transformer output tubes amp is what I do.
Yes Pico Audio is pretty elusive. I was told it was formed by a Hong Kong audiophile enthusiast and they are made in Hong Kong but I take this with a pinch of salt since it could be from China. I found their products via a distributor MasterPro on the backstreets of Hong Kong and most of the materials are in Chinese but I have consolidated some of the materials here. Please bear with me about the formatting since most of it was translated from Chinese. BTW I am in no way affiliated with them or have any monetary gain from this product. I am just an end user like yourself trying to experiment and find the best sounds for my personal enjoyment. What I do like about it is that you can see everything for yourself of what's it's made from and they even supply you screw drivers and adopter tube kits. They will even cover the warranty if you make changes to it and modify it. It's like the raspberry Pi of the audio world. Here goes.....
Pico Audio is an audio brand under Pico Entertainment, focusing on the development of portable audio products. "Pico Audio – Origa" is the first product officially released, the world's first fully discrete and replaceable vacuum tube hybrid portable headphone amplifier.
Design concept
Once upon a time, there was a myth about thrust among portable audio enthusiasts, your XXX is not enough to push the headset, you need to balance a balanced DAP, you need a station amplifier to push the headset well, and so on, but is it? It must be like this? Many years ago, a large push-type portable amp appeared on the market. Friends with hands-on ability will popular DIY. Among them, there are some heretical products "portable vacuum tube amp", but generally It is a combination of noise and background noise, and the thrust is not very good. By coincidence, the Pico Audio portable vacuum tube and transistor hybrid amp with both low noise and thrust was developed.
Pico Audio - Origa's vacuum tubes work in the way of vacuum tube buffering, with Class-A amplifier circuit of fully discrete transistor structure, providing powerful thrust and ultra-low noise and dark background. The overall tuning direction is also biased towards the average, so that you can feel the change of replacing the vacuum tube more.
Modular Architecture
Origa can freely replace different brands of vacuum tubes, supports 6DJ8 and 12AU7 series signal tubes, and can freely replace op amps (only support +-18v or above op amps, see the list of accessories for details), providing maximum tuning freedom for users Find the best sound yourself.
Highly adaptable configuration
In addition to the modular structure, three magnifications of high, medium and low are also available for adjustment. To match headphones with different needs, the body also has a 2.5+3.5+4.4 socket output (single-ended), reducing the need for conversion plugs. possible double distortion.
Some parts are as follows:
2.5, 3.5, 4.4 headphone jack made in Japan
Vishay High Precision Potentiometer
Panasonic 0.1% High Precision Chip Resistors
Japanese Takman Resistors – The Most Popular Fever Resistors for Japanese DIYers
Panasonic POSCAP, SP-Cap and OS-CON Capacitors
Beryllium Copper Gold Plated Tube Pins
The latest version of the transistor constant current source vacuum tube signal circuit improves the power supply circuit of the vacuum tube, pushes the performance of the vacuum tube to the extreme, and the sound field momentum and dynamics will be optimized as a whole.
Product content includes:
Transistor version upgrade vacuum seat 6DJ8+12AU7 set
A set of upgraded titanium gold-plated gongs and screws
An upgraded lithium battery charger
One QC 3.0 to DC 12V power cord for emergency use
Detailed Specifications and Supplementary Information
Pico Audio – Origa (with upgrade kit)
Tube
Solid State hybrid Headphone Amplifier
The vacuum tube works in the way of vacuum tube buffer, combined with the full discrete transistor structure amplification circuit
Composed of Tube Buffer and Full Discrete Circuit
3.5 Socket input (single-ended) and 2.5+3.5+4.4 Socket output (single-ended)
3.5 Single-end in and 2.5+3.5+4.4 Single-end Out
High, medium and low magnifications are available for adjustment
High Mid Low Gain output selection
Can freely replace different brands of vacuum tubes, support 6DJ8 series (ECC88, E88CC, 6922, CCa) and 12AU7 series (ECC82, E82CC, ECC802S) signal tubes
Support 6DJ8 (ECC88, E88CC, 6922, CCa) & 12AU7 (ECC82, E82CC, ECC802S) series tube
Changeable OP-Amp Design (Only support +-18v or above )
Changeable OP-Amp Design (Only support +-18v or above)
5-8 operating hours (depends on tube & OP-Amp usage)
Dimensions: 165mm
(L) x 76mm(W) x 38mm(H) Size: 165mm(L) x 76mm(W) x 38mm(H)
Price: about HKD$8980
Recommended IC:
Discrete ICs:
Sparkos Labs – SS3602
Sonic Imagery Labs – 994Enh-Ticha DUAL
Single op amp IC:
MUSES03 x2
627SM x 2
128SM x 2
Dual op amp IC:
OPA2107SM/BM
OPA2111SM
OPA2604
AD827SQ/AQ
AD797SQ
5532 ceramic seal
OPA2132
OPA2134
Unusable IC:
BUF634 (low magnification will produce micro-DC and dismantle sound, which will burn headphones)
Muses 01/02/8820/8920 series (3-4V higher than the rated voltage of IC, equivalent to overclocking, it will heat up and be very It is about to be broken, after it is broken, there may be DC output, which will burn the earphones)
