Excellent! Musicteck also has the spare Battery Modules for the C9 available for pre order as well.
Cayin N6ii, Unlimited Possibilities: a fully modularized smart DAP
- Thread starter Andykong
111MilesToGo
Looking for some specific help here. Is there somebody out there who owns a DAC device which displays BOTH the incoming sample rate AND incoming bit depth? From looking around I found e.g. the Mytek Brooklyn to do that. There are lots of DACs which display the sample rate (from AudioQuest DragonFly to Chord Hugo 2 which I own myself), but bit depth information is extremely rare.
It would be very helpful if such DAC would accept input from the I2S digital out of the N6ii, and - more easily - from the S/PDIF out.
Please note: This call for help is in no way related to the N6ii itself !!!!!! It is related to the Qobuz Android app.
Thanks in advance, PM highly welcome.
Richardhoos
Question for my fellow Cayin owners! ... has anyone connected the Cayin to an external amp like a HeadAmp GS-X Mini (or similar)? So that you’d be using the Cayin as DAC but the external amp on amp duties obviously. What cable or cord would you use for that? Thanks in advance fellas.
(right now I’m using a chord Hugo 2 and the GSX Mini in my desktop set up but I’m wondering if I can use my Cayin DAP for both portable and desktop use and sell the Hugo)
bluestorm1992
You will need a 4.4 to dual XLR cable. I believe you can find one such on Amazon.Question for my fellow Cayin owners! ... has anyone connected the Cayin to an external amp like a HeadAmp GS-X Mini (or similar)? So that you’d be using the Cayin as DAC but the external amp on amp duties obviously. What cable or cord would you use for that? Thanks in advance fellas.
I have paired my N6ii A02 with the Xiaudio Broadway Amp and got very positive outcomes.
mashuto
- Sep 23, 2016
Welp, been reading up a little on r2r dacs, and I decided to preorder the R01. Here's to hoping it produces a new experience thats unique from the other boards. I realize it'll likely be fairly marginal, but here's to hoping!
Congrats! The R01 club is growingWelp, been reading up a little on r2r dacs, and I decided to preorder the R01. Here's to hoping it produces a new experience thats unique from the other boards. I realize it'll likely be fairly marginal, but here's to hoping!
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
I think with Cayin's track record, they won't disappoint. It's a really good value, for 600 bucks you can transform your N6ii to a R2R unit without the LP software issues. Plus you get all that nice streaming haha
mashuto
- Sep 23, 2016
I have the A01 and E01 and use the n6ii mostly for streaming single ended to iems. I have been pretty happy with it so far and there's a definite (albeit minor) difference between the A01 and E01, so I'm hoping r2r brings something unique here.Congrats! The R01 club is growing
Honestly my only "concern" at this point with the n6ii is just that it's running a fairly old version of android so I have concerns it may become obsolete sooner rather than later and that streaming apps may no longer receive updates or at worse stop working. Hopefully though that doesn't happen for quite some time.
111MilesToGo
I do that with a Violectric HPA V281. Great with proper line-out Cayin modules (cf. above, posts by Andykong).You will need a 4.4 to dual XLR cable. I believe you can find one such on Amazon.
I have the iFi Audio 4.4 to dual XLR balanced cable which was pointed to by @Andykong a while ago here. Probably more appropriate than Amazon stuff ... (unless iFi sells via A). I got mine from their German importer.
Does anyone switch motherboards without screws? I'm curious if I can getaway not using screws every time I want to switch motherboards when traveling.
Traveling with a screwdriver is something I'd like to avoid haha
mashuto
- Sep 23, 2016
I don't believe theres any reason you would need the screws, except to hold the board in place so that it doesnt disconnect, which I imagine might be bad if its powered on. If you have a case to hold it snugly in place you would probably be ok. Personally though I think I would still opt to take the screwdriver and screw it in.Does anyone switch motherboards without screws? I'm curious if I can getaway not using screws every time I want to switch motherboards when traveling.
I’m fairly sure you can hot swap the motherboards , so I don’t think the screws are necessary as long as the module is secured maybe by a case ?
jmills8
Previously known as bmiamihk, jmills2
Duct tape it , the mans way.Does anyone switch motherboards without screws? I'm curious if I can getaway not using screws every time I want to switch motherboards when traveling.
Nostoi
Alongside the C9, I use my N6II/A02 with my desktop Sparkos Aries Lab amp quite a bit and it sounds phenomenal. I also have the Hugo 2 and could quite easily see the A02 module being a decent DAC replacement.Question for my fellow Cayin owners! ... has anyone connected the Cayin to an external amp like a HeadAmp GS-X Mini (or similar)? So that you’d be using the Cayin as DAC but the external amp on amp duties obviously. What cable or cord would you use for that? Thanks in advance fellas.
I use the A02 module connected to the Venture Electronics Defiant transportable amp (a beast of power AND musicality), and really like this comboQuestion for my fellow Cayin owners! ... has anyone connected the Cayin to an external amp like a HeadAmp GS-X Mini (or similar)? So that you’d be using the Cayin as DAC but the external amp on amp duties obviously. What cable or cord would you use for that? Thanks in advance fellas.
justsomesonyfan
- Sep 24, 2013
ended up going for the ifi diablo instead of the n6ii r01, hope y'all enjoy it, i'll come back around when the dual ladder flagship is announced
