I will do. I have the stock plus three modules to try out.Check the T01 is you have it ...
Thank you
How does the N6ii with E02 compare to the N8?Late to the party whilst everyone is rocking in the N3pro thread
Borrowing a N6ii with several modules.
Cayin N6ii with module E02 and Campfire Audio MW10.
Quite stunning.
i loaned the N8 for a time and enjoyed it.
I’ve just had a message on the N6ii that says Google Play Store is using up battery. I’ve tried to look at shutting it down but I’m not sure how. Can someone help?
Edit: my battery is draining quite a bit. I charged the dap Friday evening to 98%. I didn’t use it then until this morning, where it was at 71%. I used this morning for about 2 hours and it dropped from 71% to 47%.
Thanks. I’ll wait to see if it shows up again and I’ll make a proper note of it. The issue here was that I pressed on the message expecting it to take me to the required place, but instead it just disappeared. Something was eating my battery though.Are you sure it's Google Play Store? Or is it Google Play Services? If it's Google Play Services then you can't really shut it down as several apps will use the functions that it provides. If it's Google Play Store then you can just quit it like any other app.
I had exactly the same thing happening, including I am not sure about the exact identity of the complaining app/service either. Thus I‘ll wait and see, too.Thanks. I’ll wait to see if it shows up again and I’ll make a proper note of it. The issue here was that I pressed on the message expecting it to take me to the required place, but instead it just disappeared. Something was eating my battery though.
Did you also get a big battery drain around the time of the message?I had exactly the same thing happening, including I am not sure about the exact identity of the complaining app/service either. Thus I‘ll wait and see, too.
Oh, I knew this would be asked. The answer is that I am not sure, at least I didn‘t observe a drain. Had been doing s.th., when that message popped up. I clicked it, and it vanished, same as yours did. I then checked whether Google Play looked like doing s.th., but it didn‘t. Thus I went ahead and rebooted the DAP. Nothing peculiar up to now, maybe one or two days later.Did you also get a big battery drain around the time of the message?
any news about the update of the filter issues ?
New?
my N6ii E02 have been collecting dust, because the filter issues.any news about the update of the filter issues ?
Cayin need to do something fast.
