I got my N6ii with E02 to audition today. On initial impressions The N6ii E02 has more bass impact than the M15 and a more intimate presentation. It isn't as airy as the M15 with my Solaris 2020. I am also noticing some noise from the player like a low whistling/static every now and then. Not sure if that is normal or if there is something wrong? It almost sounds like when you have a bad connection with a cable. But I don't get it at all on the M15. I also am not sure how much time this E02 motherboard has on it as it is supposed to be an open box demo for audition purposes. Initial impressions are I prefer the M15 to the N6ii w/E02. I do like the added weight to the bass though on the N6ii. I wish the soundstage was as airy as the M15. Maybe this board needs some time to run. I only have it for a couple of days, so will let it run a bit and see if it changes.
I think @twister6 said he had it on burn in for 4-5 days before assessing it. @Vitaly2017 is going to burn it in for a minimum of 200 hrs. Perhaps this is worth doing just in case, then try it again?
