originalsnuffy
Andy,
Your thoughtful and helpful answers mean a lot to me and I suspect most other customers and users of this and other Cayin products. I want Cayin, the N5II, and you to succeed.
The only other time I saw a level of service this excellent was when Joe Bloggs was at FIIO. Your other support associate is very helpful also.
I feel good that most key "show stopping" issues will be fixed in this release or the next. Thanks again.
I do think the USB bus may be behind some of the issues I am seeing beyond the volume bug.
Before my machine became largely unresponsive and required a factory reset and a software file rebuild, I had been transferring files from one usb memory card bank to another in a fairly large volume. Perhaps that is a indication that some more arbitration of USB related bus activities is needed.
Perhaps Cayin might consider including a USB-A to USB microsd adaptor in the box, which is something that Shanling does. It would appear that large file transfers to or from the device can be problematic based on my experience. So the adaptor may be a workaround.
By the way, I think it is quite possible that the USB cable included with the device is not of particularly good quality. I have much better results when accessing the machine with other cables that I have.
