- Nov 29, 2013
@CayinSupport - another problem I seem to be having is that the Scheduled Power Off resets every time it turns off and on again. Seems like to should be something that can be permanently turned on!
It is normal.@CayinSupport - another problem I seem to be having is that the Scheduled Power Off resets every time it turns off and on again. Seems like to should be something that can be permanently turned on!
Stay updated on Cayin at their sponsor profile on Head-Fi.
Scheduled Power Off is like a sleep timer you use it as you need it e.g. using the DAP at night and you planned to left it as you sleep. If you want a more permanent solution, Idle Shutdown is what you asked for. Yet the DAP wont turn off automatically while still playing.@CayinSupport - another problem I seem to be having is that the Scheduled Power Off resets every time it turns off and on again. Seems like to should be something that can be permanently turned on!
There is no fix you can do by yourself. Cayin engineers have been working on it for over a year but they could not solve it!.. It's like a joke but true..Anyone use Cayin N5ii as USB DAC ? I just try to use but I hear some noise come and go all the time and I already installed universal driver to my Windows 10. How to fix this please?
Thanks for your kindness. I am sure Cayin N5ii is a great product. Wait for the day Cayin teams can conquer the problem. Cheers.There is no fix you can do by yourself. Cayin engineers have been working on it for over a year but they could not solve it!.. It's like a joke but true..
I have had this happen to the n5ii. I left it for an hour or two and was then able to power on after connecting to PC.Charged my N5iiS all night and now it won't turn on. The little light just below the volume spinner is on but the screen is black. Anyone know how to force boot the device?
EDIT: Tried to turn it on/off in Recovery Mode ( power + play/pause) and even then nothing is happening)
Problem only occurs occasionally for me but can't work out what triggers it.
She be a temperamental beast, but I forgive every time due to the sweet sound.
is the screen off or is the screen is just black
No, that's blatantly false. HiByLink is not supported on the N5ii.I have a quest. From this link: https://www.headphonezone.in/blogs/...things-about-the-cayin-n5ii-that-set-it-apart
"you can easily access the N5ii via HiByLink and control it using your smartphone." -- Is this real? I have never tried yet. How to do it please?
