Has anyone installed and used the PLEX app on this device to play FLAC files? If so, thoughts on how it worked?
Cayin N5ii Android based Master Quality Digital Audio Player
- Thread starter PinkyPowers
blue212
- Dec 6, 2016
I too would be interest to know how Apple Music works on N5ii. Can you download to SD card for offline listening?
How does the Apple Music app work on the N5ii in your experience?
apple music app works smoothly on cayin n5ii, just like spotify
Save song into sd card or internal, and play it while offline
blue212
- Dec 6, 2016
parabellum777
Yesterday some test with Tidal (firmware 3.1EN).
The player was extremely unstable: at the first launch of the app the system crashed and reboot itself.
The second time playing stopped after few seconds: after touch "Play" the system crashed again and reboot itself.
The third time I was able to play an album (with a very high battery consumption!).
I hope that the next firmware can fix this instability.
I also hope that Tidal will gives the support to Cayin to be able to select also an external microsd for downloading the offline tracks.
I was about to ask about Tidal use on this DAP, but it seems that there are still many firmware issues to solve. If it cannot save downloaded music to the MicroSd card is useless for me. I´m currently using a Pioneer XDP-300R for this purpose, but I´m not happy with the hiss, electric buzz and noises that sounds even with lower gain options selected, but at least I can use the 1st MicroSd slot (it does not work with the 2nd one) for storing offline music. Maybe the Ibasso DX150 could be the best solution.
seanwee
- Jun 9, 2015
I tried out tidal on mine and it ran smoothly. Smoother than YouTube (video drops frames, audio is smooth though)
It did consume battery faster than usual though, I'd say it drops 1% every 2.5 minutes.
seanwee
- Jun 9, 2015
Ibasso DX150? Can't find any information about it.I was about to ask about Tidal use on this DAP, but it seems that there are still many firmware issues to solve. If it cannot save downloaded music to the MicroSd card is useless for me. I´m currently using a Pioneer XDP-300R for this purpose, but I´m not happy with the hiss, electric buzz and noises that sounds even with lower gain options selected, but at least I can use the 1st MicroSd slot (it does not work with the 2nd one) for storing offline music. Maybe the Ibasso DX150 could be the best solution.
parabellum777
https://www.head-fi.org/threads/iba...le-amps-the-music-adventure-continues.874224/
Alexei23
- May 13, 2013
Hello everyone. Decided to drop in and visit from the i5 thread!
I have Finally given up on my cayin i5 and have returned it to amazon. So need something to replace it. This is very tempting as i really would've loved the i5 if it wasn't for the constant crashes. So the million dollar questions are:
1.How does the sound quality match up to the i5?
2. How is the reliability and bug situation?
3. How well does the bluetooth work?
originalsnuffy
Its been a long time since I listened to the i5. I think the sound signatures are similar but the i5 is slightly warmer. I think the N5II straddles the line between accuracy and smoothness quite well.
With regard to reliability and bugs; the software is not fully stable. The latest firmware revision is much better than before, but the units still suffer from random pauses.
I think the USB / memory card bus implementation is also not up to speed. Specifically, transferring files in and out of the machine can be touch and go. I have to reboot periodically when doing file transfers. With any luck the next firmware revision will be better.
They are somewhat reliant on HiBy for firmware which is not ideal in my opinion. Nobody in the industry will say much; but I think its interesting that Shanling's latest unit does not use HiBy. Not sure of this but I think other manufacturers are heading that way also. HiBy seems to be focused on their own machines right now and not their software customers. I would very much like to be proven dead wrong on this by the way. But proof equals solid firmware releases.
No comment on bluetooth for me; I like full resolution sound. Others can pipe in.
Overall due to firmware issues I would give this unit a B grade not an A grade. But it is capable of being an A grade machine.
CongoFather
Most of us are looking forward to receiving the new firmware update which is expected and said to be released at the end of this month. It is better to make a decision after trying the new firmware. But it may not be the last firmware to solve all the issues.. I hope they can sove all the issues but it seems less probable to me.
Currently, it has some annoying problems like random pauses, noise on usb out etc as most of N5II users had reported in this thread before.
It will make more sense if you have time to wait and see the reviews of Ibasso DX150 which has been launched,recently. A better CPU/MCU seems to be used on DX150 without SRC limitation of Android as it is on Hiby R6.. As sound is more important than any other attribute, it is better to wait and see the reviews.
seanwee
- Jun 9, 2015
Actually, although the RK3368 is newer than the RK3188, the DX200(same cpu and ram as DX150) was actually slower than the X5iii, which is in turn slower than the N5ii in actual use. This was speculated to be due to the use of android 6.0 on the Ibasso rather than 5.1 like on the FiiO and Cayin.Most of us are looking forward to receiving the new firmware update which is expected and said to be released at the end of this month. It is better to make a decision after trying the new firmware. But it may not be the last firmware to solve all the issues.. I hope they can sove all the issues but it seems less probable to me.
The HiBy R6 is way faster than all these though.
Hi, N5ii doesn't have reply gain option. But it has gain settings and DSD gain compensation options under music settings
Hello. Are there any plans to implement a replay gain feature? It is useful when listening to tracks on random from diffferent albums. They will all have different sound levels, so you have to continually adjust the volume.
Implementing this would be great. I see the N3 has it.
Hi everyone, can I use Cayin N5ii as DAC for iPhone ?
. Thanks
snbrp
Dear CayinSupport!
Please, fix this screwing seeking speed! I listen to lot of music every day and track seeking is too fast. It works well only "on the paper" but in real life it is unable to use this function. And don't advice me to use progress-bar and touch screen: this palyer has very-very bad touch sensor and if you want to skip few minutes of long song (like disk image) it is unreal. I'm talking about basic functionality, not about something extra ordinary. Please, make it useful!!! Make it exacly like in N3 and we will happy.
Total: 14 (members: 0, guests: 14)
