Hello Head-Fiers,
This is my first post, so thank you in advance for any help you can provide...
After reading this entire thread, I decided to go with the N5 over the AKJr and the X5II as my first advanced DAP. I received it a couple of days ago and it sounds great and has been fairly easy to use. I am having one problem though, I cannot get the album art to show up.
I have the setting turned on. Album art does show up for 3 albums I have downloaded from HDTracks (the album art is embedded in a .pdf file). I downloaded a bunch of album art for my other albums in .jpg format copied them over to the sd card in the player, updated the music library, played a song from the folder where the album art was copied and nothing, I just get the standard n5 violin background.
Any ideas what formats the n5 supports? Is there a size limit to the files? Have others had success doing this?
Again, thanks for all the information in this thread and for all the other information at headfi. I am just a beginner as far as audiophiles go, but I will get there.
MontMozart
