pepitomanaloto
- Jan 19, 2014
are there user programmable eq presets?
Just one custom EQ preset slot.are there user programmable eq presets?
@Andykong a second EQ preset slot would be very welcome.
It was ok...but I sold it for other gear. I considered the uber expensive Hiby R8 but I actually bought the VERY simplistic functioning Shanling Q1...primarily due to its smallish OTG form factor. Surprisingly it’s a keeper that I actually continue to use (carry—jogging).This had me worrried, I have a lot of subfolder levels too
how do you like the r6pro?
Andrew is Awesome !!!I pitched a couple of questions over to Andrew at Musicteck:
Hi Andrew,
1) Do you know if there’s a way to change the default N3 photo playback image on the N3Pro for those instances in which the album artwork doesn’t display?
2) I’m also wondering if there’s a way to have compilation artist albums display as a single album when Artist is selected? For example collaborating artists are listed as single entries (songs) when ‘Artist’ is selected (for albums that have contributing artists listed).
His reply:
Hi Kevin,
There is no way to do either of these things, but we will forward your request to Cayin so they can consider it in the future fw updates.
Best,
Andrew
mine just arrived thanks to the fast shipping from Musictek(great folks).
Be nice to get the jade case when they get it in as it seems this thing is very easy to scratch.
The UI/keys are so different from my N3 so it's an adjustment
So far I've been testing my Venture Electronics Zen 2 Omegas through the 3.5 to test the tube options and my VE Sun DICE and my Wong Kuan Wae Blurs from the 4.4 bal side.
Never really found a reasonably priced player that could do them justice without an external amp. So far so good with some compilation DSD tracks from Blue Coast and Native DSD. Gonna test the TIN P1 and my Ollo S4 later.
Is there a burn in period required for the tubes
Can't remember what I did with my old B4X
Stay updated on Cayin at their sponsor profile on Head-Fi.
Wich shop in Spain ???
Yeah I didn’t realize the hibylink must be switched off in order to connect by iPhone to the N3Pro by Bluetooth to use steaming service on my phone such as Tidal and Spotify.
Battery seems close to spec on tube mode, roughly 8 to 9 hours real usage. Didn't time the library update but it was pretty fast. The build quality is very nice and so is the wheel.
From what I remember the ui operation in folder mode is similar you can back out in order and hit the circle to go back to now playing. And if you hit back again it will remember where you are. Normal operation to me. I can try to take a crappy ui vid later. I personally have no problem with the UI it is pretty simple, kind of reminds me of lotoo paw os.
Sound wise I thought the M5s was a little to polite soubding and although good I liked my other daps at the time. This is subjective and personal opinion of course but I find the ultralinear mode to sound better than most of the daps I've heard. From memory I think sony z1 sounded a bit better, but that was a short demo. To me the tube effect adds quite a bit. I swear when I switch back to ss it sounds a bit flat- looses depth and presence/weight.
M5s I'm sure has better battery life, and is more svelte.
I just did a rudematary UI vid. You tube says it's going to take about 2 hours to load so I'll try and link it later. Ok here it is, forgive the miss hits, as I was using my phone to film it with one hand. And forgive the rabble at the end. Hopefully it will give you an idea.
Hello Andy! @AndykongSorry, Spain dealer decided to defer their order in last minutes.
Right now we have shipped N3Pro to our European dealers in UK, Poland, Netherlands, Russia, Germany and Ukraine. We have a Where to Buy page in our website but Germany and Ukraine is missing. You can contact Cayin GmbH or era-in-ear if you want to buy N3pro from them.
