DAO (Class A/AB), Dual Output Mode (P/P+), and the ultimate Hyper Mode
The
Dual Amplifier Operation (DAO) implies the same amplification circuit in two distinctive modes of operations: Class A or Class AB. The difference between the two modes is simply the point at which the transistors are biased. In the case of Class A, the transistor is biased so that it will maintain linear operation over the entire signal cycle, while Class AB will compromise on linearity but improve significantly on efficiency by biasing the circuit to respond to amplification operation accordingly. Class A is a faithful reproduction of the input signals at lower distortion, but we cannot jump to the conclusion that one is better than the others in real life.
On the other hand,
Dual Output Mode (DOM) regulates the operational voltage of the headphone amplification circuit to offer P (Standard) and P+ (High Power) modes. When we increase the voltage of our discrete headphone amplification circuit, it will not only deliver more power and improve its handling capability but also changed the sound of the discrete components. In other words, your IEM probably won’t need the extra power of the P+ mode, but it won’t hurt to have an alternative sound signature from their DAP.
DOM was first introduced in the original N8 (May 2018) while DAO was first introduced in E01 Andio Motherboard of N6ii (Dec 2019). We have implemented both features in numerous portable audio products ever since and they should be no strangers to Cayin users. We are not going to explain them in detail, if you are interested to read more about DAO and DOM, please check out our explanation n N8ii thread (
HERE).
Portable audio products always have various limitations due to physical constraints such as size, heat dissipation, and battery life, and one of the limitations with DAO and DOM is that we can’t use Class A and P+ modes at the same time. The power supply system will have a hard time trying to fulfill the power requirements of Class A with P+, and the heat generated will be substantial even when we operate in this condition even for just a short while. There was a lot of discussion “speculating” (and requesting) Class A with P+ in N8ii thread, and we decided to demonstrate its feasibility and practicality in N30LE. Unlike previous products, regardless of balanced or single-ended output, Class A, Class AB, P, and P+ modes can be freely combined in N30LE, meaning users can choose the A and P+ simultaneously.
On top of enabling the Class A with P+ combination, we have decided to develop an
ultimate “Hyper” mode. Ultimate is just an adjective within this relative framework. When our engineers prioritize audio output as the single most important factor and put all constraints such as heat dissipation and battery life asides. The idea of providing users with the most powerful audio performance mode comes into play, and this is where Hyper mode comes from.
Hyper mode in N30LE is more than activating Class A and P+ mode at the same time. It further adjusts and enhances the static working current and voltage under the Class A setting, achieving an “on the edge” operating condition that we have kept a safe distance from in the past. In Hyper mode, N30LE will sing in full dynamic without compromising the transparency and naturalness of the playback. The soundstage is expanded and well-organized.
Once Hyper mode is selected, both DAO and DOM are pre-selected, you can’t make further adjustments to these features. The good news is, The Hyper mode is independent of our Timbre circuit, so you can select Nutube Classic, Nutube Modern, and Solid-state timbre freely.
“For everything you gain, you lose something else.” Ralph Waldo Emerson
Unfortunately, Hyper mode will generate a lot of heat. The internal aluminum frame and the Titanium chassis will disperse the heat effectively (yes, the chassis become a big piece of the heatsink of the circuitry), but we strongly recommend you use this mode in well-ventilated conditions. In addition, the Hyper mode will consume a battery like a V12 sports car. Even with a 12570mAh battery, the Hyper mode will only sustain around 7.5 hours in the most demanding condition (4.4mm balanced phone out and Vacuum tube timbre), maybe shorter if we playback Hi-Res music format, turn on your screen and connected to WiFi or BT during playback. At 3.5mm single-ended phone out and solid-state timbre, you might be able to playback up to 11.5 hours continuously.
When we implement the discrete Class A amplification in N30LE, we have to make sure all four amplification channels are in near-identical gain. We have to manually match critical components and installed them to the PCB manually before reflow soldering. This is because the discrete components are not available in a form factor that can be installed with the automated PCBA process. In addition, we must control the static current so that the discrete components will remain perfectly stable operation in saturation mode, therefore adjustments is needed to compensate for the deviation caused by discrete components. As illustrated in the PCB photo below, there are
FOUR adjustable resistors in place. We’ll fine-tune each assembled PCB manually to match our reference design. All these procedures involve extra resources and are very time-consuming, that’s why discrete Class A is an expensive option, especially on compact devices such as portable DAP.
I know there is one last question you want to ask: can we implement these features in mass-production DAP such as N8ii? The critical requirements of Hyper mode (or Class A and P+ concurrently) are:
- better than the best power supply system - N30LE has the biggest battery (12670mAH) among Cayin DAPs, and the low internal resistance, high output power EDLC ultracapacitor will store and supply energy for the momentarily drain from the audio circuit.
- extremely efficient heat dissipation system - N30LE has employed multiple tricks to direct and transmit the internal heat energy, to the internal CNC aluminum frame, which in turn will,, as mentioned previously, use the titanium chassis as a heat sink. When Hyper mode generates a lot of heat energy, we need to increase the total surface area of the heat sink, which means bigger will have an advantage over smaller DAP in this regard.
