Cayin N3 Hi-Res DAP with AKM4490 DAC, apt-X Bluetooth, and Line, USB & Coax Out for $150
Mar 14, 2017 at 1:59 PM Post #332 of 6,262
If it works as I think it will work, there will be no need for a Chord Poly for my use at least.  Im thinking Bluetooth from phone to N3 with N3 USB out to mojo to headphones.  No more messing about trying to change tracks with a phone.
Yes, this will work fine, we have tested the scenario already:
http://www.head-fi.org/t/833932/coming-soon-cayin-n3-hi-res-dap-with-akm4490-dac-apt-x-bluetooth-and-line-usb-coax-out-for-under-200/195#post_13317549
http://en.cayin.cn/
Mar 14, 2017 at 2:39 PM Post #333 of 6,262
Hi Andy any idea if they will sell the n3 on amazon or ebay if yes when? Btw i like the blue color it could be shade darker of course.
Mar 14, 2017 at 2:51 PM Post #334 of 6,262
Thats great.  You have basically saved me a fortune on having to buy a poly.  For this and no other reason i will be getting an N3 that and the fact i can BT to my BT headphone when needed and have a Cayin player again.
Mar 14, 2017 at 5:44 PM Post #335 of 6,262
Can anyone tell me whether this will have more driving power and a better DAC than an iPhone 6, from a spec level? I made the mistake of comparing my iPhone to a Sony zx100 using the same lossless song with my rockets at the Tokyo Sony store. It got me looking at trying out an entry level DAP and seeing how much I use it.
I can't comment on the sound quality against a "competitor", if you were to compare the driving power from spec level. The rated power of N3 will be roughly 10 times higher then iphone 6:
Rated Output at 32/33 ohm
iphone 6 = 26.39 mW,
N3 = 130mW+130mW
http://www.anandtech.com/show/8554/the-iphone-6-review/11
Regarding the digital audio capability, iTune does not support DSD and last I checked, the lossless audio capability can support up to 24BIt/48kHz in PCM (thanks to the correction from originalsnuffy). The N3 can support native decode DSD64/128/256, and upto 32 Bit/384kHz in PCM (please refer to music format table presented yesterday). The numbers also suggested the N3 is superior in DAC section.
http://en.cayin.cn/
Mar 14, 2017 at 5:49 PM Post #336 of 6,262
I assume you are located in US, please correct me otherwise.
Our US distributor has announced N3 availability on their website and marked the availability as "after 20 April 2017", you can either buy from him directly from his website. Musicteck probably will put the N3 on his Amazon shop after he received the N3 into their inventory, you can contact them and find out the latest progress from them.
http://www.musicteck.com/
http://en.cayin.cn/
Mar 14, 2017 at 9:49 PM Post #337 of 6,262
N3 = 130mW+130mW
Regarding the digital audio capability, iTune does not support DSD and last I checked, the lossless audio capability are basically CD quality, which is equivalent to 16BIt/44.1kHz in PCM (please correct me if iTune can support higher resolution now). The N3 can support native decode DSD64/128/256, and upto 32 Bit/384kHz in PCM (please refer to music format table presented yesterday). The numbers also suggested the N3 is superior in DAC section.
Works for me, thanks!
Mar 14, 2017 at 9:50 PM Post #338 of 6,262
Andy, I believe it's earlier than that
  MusicTeck website actually says available on March 20th and hopefully both from their on-line store and Amazon.  As soon as I see it up, I will make sure to let everyone know!
Mar 14, 2017 at 11:48 PM Post #340 of 6,262
N3 = 130mW+130mW
Andy,
I admire your professionalism in not comparing your self  to the competition.  It is probably best if that is left to the user community.
The only observation I would offer is that the iphone is capable of playing back 24 bit 48 khz music files.  Of course you need to feed it an ALAC file with those specs (but no more than that).   I personally don't think that the iphone has the proper circuitry to bring out the benefits of files with those resolutions, but that is what is can natively handle.  Of course those would be user created files; you can't purchase those from Apple directly.  I have converted some hi res files on the iphone to that spec and they do play back.  Personally on that device I am not convinced that using up memory space for the higher res files is worthwhile.  Others may disagree (around here that is a given).
If I recall; the N3 has a DAC mode.   In that case, the iphone could function as a storage tank for higher res files that are then played back through the N3.  I have done that with my iphone with other devices.  It does require the camera connecting kit from Apple.   The good news for Cayin is that you would still end up with a N3 customer in that scenario.
Mar 15, 2017 at 3:39 AM Post #341 of 6,262
With my recent experience comparing my phone to a real DAP, I'm inclined to agree. Leaving everything on my phone in 320 for casual listening in the gym and such, and getting a DAP for a hi-fi experience seems to be the logical solution.
Well, I've ordered an N3. I'll see how it goes!
Mar 15, 2017 at 10:13 AM Post #344 of 6,262
Code:
[color=rgb(33, 33, 33)] Any expectation of this dap to arrive at aliexpress with good prices.[/color]
Yes but only when they're widely available and more stores have stock. Until then there will be sharks that try to rip people off.
