- Jan 29, 2010
Getting difficult to recommend this player to people due to the issues with Tidal. I do wonder if it's a hardware issue.
I'm sorry but what are those issues?
It is a music player and it sounds great.
I quoted that sentence above because I stop questioning too.....I marvel at it but don't question it![]()
It has been a pleasure dealing with a rep that is not paranoid that every critique is a personal affront. If you own Cayin...good job! If you work for them...they should give you a raise. one of the better arranged and implemented tours I have seen and joined. Joe Bloggs was the man to beat and you have. Other reps should follow your lead.
Stay updated on Cayin at their sponsor profile on Head-Fi.
Ah thanks, have been looking thru the pages for something like that. So only a flash drive or card reader if I want to expand the capacity and keep the portability.
Lately i had experience 3 problem with cayin i5
(1) Volume knob not working (solve by locking the screen and reopen)
(2) Song will not jump to the next song when finish (had to do it manually) happen twice now when playing in folder
(3) Screen will not reopen after auto lock(all button function doesn't work) can't shut down also. Had to do a reboot by clicking both power and next button
I have added numbers to your text for discussion purpose.
(2) is a reported instance, the problem seems to occurred randomly and we can't pin-point the cause of this bug, fortunately this only happen occasionally and won't cause too much problem as you can continue playback by pressing the next button on screen or on the side panel.
For (1) and (3), I need to ask what version of firmware are you using right now? They sounds like bugs that have been rectified by v1.8 firmware already.
I have same issue can't read from USB OTG for flash drive, card reader and HDD with separate power supply.
And I dont know how to send my Cayin for replacement..Any idea?
No mean't it how it reads.
Tidal is not my main priority, I don't even subscribe to it, just tried it on trial. However if you buy an Android based player with wifi you should expect it to work with no real issue, that can't be guaranteed with the I5.
Just out of curiosity, ... if i5 does not have WIFi function at all, you'll consider the i5 "recommendable" at $499?
I am confused about the status of this issue, because I understood it was being addressed.
I want to stream Tidal lossless, and to Download lossless - Has anyone achieved this?
As I can do both with my android phone, I assume that it should be achievable by an android music player
At $499 , it is an incomplete solution if it cannot support lossless streaming , in my opinion
Is there an easy way for me to connect i5 to Mojo? I want to listen with my Beyerdynamic T1 but i5 is not able to drive it properly.
Thanks for your help.
(1) Play by folder: we have a feature called Play through Folders, and you can turn on (or off) this playback contrl at the HiBy menu (wipe from left to right).
