preamp tubes helped significantly! Stock JJ were so noisy because my computer is very close and next to power conditioner. Moving around the HA-6A amp plug (upgraded power cable) I noticed the scrolling signal noises stopped but still had loud hiss even with 4.4mm. Swapped out to another old 12au7 I had and it got better. Ordered green label baldwins for $45 per zmf recommendation and now I can barely hear the hissing. Hiss is still obvious with xlr but with 4.4mm its almost all gone. You have to really pay attention with ZMF to hear the hiss but with HD800S I really can't tell because it's open back and I prob have other louder sounds in my room. Got some preamp siemens E82CC and SE KT88's after reading some reviews in this thread. Preamp tubes like Telefunken NOS smooth or ribbed you can't go wrong with either. Also look for the tesla E802CC as they are suppose to be very close to the expensive TeleFunken E802CC. Just watch out for fakes! But as far as what ZMF recommended to me which is the GEC KT8C w/ adapters and sylvania green baldwins anyone would say this is a great amp. I just ordered the other set of tubes to rotate monthly or so and also to keep the wear and tear down. I even got a small case with foam to store my tubes thanks to @ThanatosVI for the inspiration! BTW, I have iphone, bluetooth lamp, and mesh wifi all near my HA-6A and even with cage off no noises. Just ittybittytiny hiss with 4.4mm @hung031086 edit** forgot to mention I'm using A26 dac and use the volume attenuator with HA-6A volume staying put at one tick past 12 o'clock most of time unless I'm listening to Jazz / Orchestral.
If we are comparing the tubes that are currently mass-produced, JJ is actually one of the lowest ones in terms of tube noise. For unknown reasons, the vintage tubes are indeed quieter than the current production tube, but we can only use vacuum tubes that can guarantee a steady supply during the 5+ years of production time of the amplifier.
Stay updated on Cayin at their sponsor profile on Head-Fi.
