bluestorm1992
Understood. Yes for Broadway I did not hear any difference when the mains powered or not.Oh yeah, I meant to refer to the balanced version.
If I'm not wrong they can also be powered just with 4 of the same batteries as the C9, so the only "advantage" they have is a larger physical size (which is usually an advantage but hey...)
This is assuming, of course, that you don't hear a big difference between the Broadway depending on whether it's mains connected at the relevant time.
Happy lunar new year @Andykong and all![]()
I think performance wise, C9 and Broadway are really close. What could be telling them apart is the tuning. The tuning of Broadway is done using the Diana, so by default it is the perfect pairing with it. C9, on the other hand, is intended to fit a wide range of IEMs and headphones, so comparing it (or really any Amp) with Broadway in terms of driving the Diana is really setting a high bar for it. Even in this, I would say C9 does an excellent job.
