Are you kidding me? Now I have to worry about what batteries I use?Agree. These orbtronic ones sound calmer to me with better clarity.![]()
Cayin C9: Dual Nutube, Fully Balanced Class A/AB Portable HeadAmp
- Thread starter Andykong
- Oct 14, 2013
You don’t have to, the stock batteries already sound great. It is just for people who would love to maximize their system potentials into the “last drop” of %Are you kidding me? Now I have to worry about what batteries I use?
bluestorm1992
No you don’t have to. The stock ones are fine. As Vince said, this is really just the last 1%. I will rec it mostly because of its extra capacity.Are you kidding me? Now I have to worry about what batteries I use?
Narrator: And yet they all knew that yes... yes indeed @HiFiHawaii808 had to worry, and it would only be a matter of time until he purchased some for himself.
jmills8
Previously known as bmiamihk, jmills2
You also have to worry about the room temperature. It will sound best if you listen/test your music in a walk in freezer or place your gear in a regular freezer and gently close the freezer door on your cable. Another worry is ear wax best is to remove the wax in the center of your ear canal and leave the wax coating your ear canal walls. Actually if you can freeze this wax it will allow the treble to travel much easier into your ear drums. Epic conditions.Are you kidding me? Now I have to worry about what batteries I use?
Nostoi
Anyone know where these can be ordered in EU? Shipping batteries from the US doesn't seem possible.BTW, anyone interested in getting new batteries should consider this, as has been recommended several times here. I have used them for a couple of days now. Longer battery life and even cleaner sound.
https://www.orbtronic.com/3500mah-18650-imr-battery-high-drain-rechargeable-orbtronic-li-ion![]()
MarkParity
Formerly known as User9876
Not that I can find, but if you search for Panasonic 18650 3500mAh you will (most likely) get the same cell as these are again, most likely just the same Panasonic cells with a branding shrink wrap applied.Anyone know where these can be ordered in EU? Shipping batteries from the US doesn't seem possible.
Nostoi
Thanks, I did indeed find these though no idea about their quality. Not so much interested in alerting tonality, but if they run a little longer than stock Sony ones, then winning.Not that I can find, but if you search for Panasonic 18650 3500mAh you will (most likely) get the same cell as these are again, most likely just the same Panasonic cells with a branding shrink wrap applied.
MarkParity
They look OK, The NCR18650GA part number was a number I kept seeing when searching for these too.Thanks, I did indeed find these though no idea about their quality. Not so much interested in alerting tonality, but if they run a little longer than stock Sony ones, then winning.
Had a week now with the C9. Really happy with everything. Great buy!
Tube class A is my preference. This thing has oodles of power.
bluestorm1992
My goodness, the Kennerton Rognir is GOOD with C9.
Yeah, but the Panasonic label has a much richer bass response. Haha.Not that I can find, but if you search for Panasonic 18650 3500mAh you will (most likely) get the same cell as these are again, most likely just the same Panasonic cells with a branding shrink wrap applied.
111MilesToGo
Okay, I have posted a detailed description of my electrical noise issues over in the N6ii thread now:
https://www.head-fi.org/threads/cay...ly-modularized-smart-dap.904153/post-16412182
I would be grateful if you folks here would visit the N6ii thread and help me out over there.
Just an effort to get the answers into one place, please! Thanks.
Well, this issue has been clarified and resolved now. Please follow up here:
https://www.head-fi.org/threads/cay...ly-modularized-smart-dap.904153/post-16422925
hi all
need your help here,
I bought a c9 just 3-4 months ago, used it a few times, but now when I press the power button, it stays for a few seconds and shuts down. the green lamps do not even light.
the c9 is connected to the power line, 4 batteries in, and on the battery indicator it is showing 4 orange lights while plugged to electricity however shows no indicator at all when I plug out of electricity.
I tried to charge the batteries with a charger I have, It shows they are full, but once I put insert them into the c9 it shows not signs of battery.
I think I used the c9 about 10 times until this happened. Does anybody know this error?
thanks.
thanks.
Did you try to turn on the C9 when not plugged into AC?hi all
thanks.
Total: 25 (members: 0, guests: 25)
