Thanks, Andy. Please make sure to test with the DX300 in High Gain as well as the C9 in High Gain. I use line out on the DX300 with volume set to 100.My limited technical understanding agree with Whitigir, I can't think of any scenario that an amplifier can damage its source equipment when there is no feedback loop in the signal path. The fact that Shecky504 can used his DX300 with C9 for several days also ruled out a short circuit problem in C9. If the C9 is having a short circuit when connected to his DX300, it shouldn't last beyond 10 minutes.
We have borrowed a set of DX300 and conduct some test in our factory after we received Shecky502's email complaint. So far our testing set is working perfectly alright. Will report after we have complete our test.
Cayin C9: Dual Nutube, Fully Balanced Class A/AB Portable HeadAmp
- Thread starter Andykong
Shawnb
- Dec 2, 2012
May I ask if someone could give their views on these 4.4mm to 4.4mm interconnects to connect a C9 to an N6ii A02 please? Not many to choose from out there unless one custom makes them which then gets very expensive. if you have any recommendations of your own please let me know. Thanks for your time.
https://penonaudio.com/penon-totem-audio-cable.html
https://zeppelinandco.com/products/...player-tws-hum-tara-ic?variant=29593493209160
https://www.lazada.sg/products/44mm...ect-cable-by-infinite-cables-i1449040483.html
https://www.amazon.co.uk/dp/B08KTJ4...colid=24PFG2R6A5UX&psc=1&ref_=lv_ov_lig_dp_it
https://www.ebay.co.uk/itm/4-4mm-Ma...&_trksid=p2060353.m1438.l2649&redirect=mobile
https://www.ebay.co.uk/itm/Audiocra...trksid=p2047675.c101195.m1851&redirect=mobile
Im looking at Eletech Iliad interconnects for when I get the C9. May be a bit more then you want to spend
Not out yet so give to contact them directly.
MarkParity
Formerly known as User9876
Does the DX300's AMP11 module implement the ground internally? Is the ground done properly, if it isn't that may be the cause of the issue.
A similar thing happens with the e1da 9038s it has no ground at all as it uses a 2.5mm TRRS connector. Some users have connected theirs to an amplifier and damaged the output stage, as there is no ground some large stray voltages can occur there is nowhere for them to go, some op-amps just don't like that and let out the magic audio smoke.
Review (Chinese):
https://post.smzdm.com/p/a7do3qmo/
With Google translate:
https://translate.google.com/translate?hl=&sl=zh-CN&tl=en&u=https://post.smzdm.com/p/a7do3qmo/
III. Sound overview
1. Power
I think that for an headphone amplifier, power is definitely one of the most important issues to be discussed.
The power level of the C9 is, in my opinion, one of the top amplification levels in the field of portable devices. Even when compared to many regular desktop headphone amplifiers in the thousands price range, it is no less impressive.
The C9 can drive any earbud to its highest level of sound basically perfectly; most big headphones can play their sound level and characteristics normally and stably under the C9's drive; and for some flagship big headphones that are very difficult to drive, the C9 can also guarantee to drive them to a relatively good sound state.
I think that basically, the C9's driving ability can probably reach the level of a medium level desktop headphone amplifier amplifier. For many audiophiles, this kind of driving ability is basically enough to meet most of the needs.
2. Sound
The power is actually more of a general framework and a conceptual outline, and it is natural to evaluate a device by its sound performance.
The C9 gives me the most intuitive feeling that it has a strong power framework, but also has a sense of sound stability, layering and a unique sense of rhythm.
The C9's sound is very stable, balanced, supple and natural, and does not become extreme, distorted or distorted. To use an analogy, it's like a football player running at high speed and still being able to control the football with agility and ease. This is why the C9's sound gives a sense of weightlessness, or "control" as we often call it.
In terms of layering, the C9's sound is not only layered in terms of spatial position, but also in terms of the differences between the various levels of pitch and timbre. Normally, in a high drive state, the pitch of the sound elements tends to rise and the timbre tends to homogenise in a more intense state. The C9, on the other hand, unfolds the sound methodically, giving it more variety and differentiation to better express the senses and state of the music.
The sense of rhythm is more the Cayin's forte. I found the C9 to be somewhat more restrained in its sense of flavour. Compared to the more mellow, warm flavour of the Cayin portable players, the C9 is more balanced and relaxed while maintaining the same gentle, moist style. It should be said that the C9 somehow tweaks the Cayin's more traditional tuning flavour to a certain extent, making the sound more subdued and listenable.
And if compared to most other portable headphone amplifiers on the market, the C9 still has a warmer, relaxed sound with a bit of colouring that makes the sound more musical and gives the C9 a wider range of compatibility in terms of sound style.
3. Matching
In terms of front-end pairing, I think we should try to pair the C9 with a player or decoder that has a high quality of decoding capability as a front-end, because the C9 is basically an "end" amplifier in the on-the-go segment, and a front-end with a high quality of decoding capability is the best way to make the best use of its capabilities. As far as the players I've tried to pair with it, I think the R8 is an ideal combination, while the Cayin N8 and N6ii are two players that work well as a "suit combo", and all other DAP at $10K (RMB) or above will offer very good result when paired with C9.
Of course the N6ii's preamp output connected to the C9's pure power amp mode is a rather interesting way to play, so if you're interested you could try it out.
In terms of headphones, I think the C9 will work with most big headphones. At least from a driving point of view, the C9 can drive most big headphones to a more normal working condition, even the flagship level big headphones or some headphones that are known to be difficult to drive.
The IEMs are the most surprising aspect of the C9; the C9 is very compatible with IEMs, and often those that are easy to "drive through" are driven by the C9 in a measured, well-organised manner, with no over-reaction or distortion at all, allowing the IEMs to be driven at a higher level without being affected by the sound. The sound is very stable and natural.
The C9 is a great way to hear the true strength and potential of some of the "hard to drive" IEMs and some of the high resistance flat headphones.
4. Modes
The headphone amplifier panel has a couple of selective hardware buttons to switch between various modes of operation. I briefly compared them.
The difference between high and low gain modes can basically be seen as a level adjustment switch. In high gain mode, the drive is a little more powerful, but the sound is also slightly more fidgety; in low gain mode, the drive output is smaller, while the sound is a little more delicate. The overall framework and stability of the sound is basically the same in both modes, but there are only differences in the drive and detail of the sound, which can be switched depending on the different headphones.
The tube - transistor mode, the two mainly in the fullness of sound and tone differences, because the issue of bile and stone amplification in the HiFi field belongs to the debate for decades, I naturally can not presume to say the advantages and disadvantages. I just think that, similar to most audiophiles, the sound in tube mode is more warm and delicate, while the sound in transistor mode is more balanced and atmospheric. Of course, for me, I prefer the C9's tubes because, on the one hand, the use of tubes is still relatively rare in the portable world and such a sound is rare; on the other hand, I find the C9's tubes more listenable with most headphones.
In terms of amplification categories, I don't think there is much difference between Class A and Class AB in terms of my intuition. However, I do feel that the output of the Class A amplifiers is a bit greater.
As for the pure post-amp mode, I experimented with the N6ii and found it quite interesting, but I don't have any other suitable pre-amp outputs on hand, so I won't go into too much detail.
IV. Headphone adaptation experience
For a long time, we have almost been accustomed to the idea that large headphones need to be paired with a desktop computer for normal sound effects, plus the structure of the large headphones themselves, and not suitable for use on the street, so it has not been looked at with portable systems to drive. In recent years, as players have gradually 'expanded', audiophiles have begun to experiment with using their Walkmans to drive big headphones, and although some progress has been made and initial results have been achieved, in the general sense that they can be considered 'listenable', there is still a certain amount of difference between the real power of these big headphones and the real power of these headphones. The C9 is a portable amplifier of this "ultimate experience" level, but how does it perform with big headphones? We have selected a few big headphones from different brands that are representative of the C9.
Sennheiser HD600 (old version)
I do not need to elaborate on the classic degree of this headset, it can be said that to a certain extent represents an era of big headphones, that solid, heavy, very hall sound can be said to be rooted in the minds of many enthusiasts a sound symbol and brand taste. Of course, the HD600 is actually a not too easy to "serve" headphones, the lack of power is often the result of too "warm, muddy" sound state, and even the sense of field can be confusing. To a large extent, this is also a common problem with HD600s driven by Walkmans and even some entry-level desktop units.
With the Cayin C9, the HD600 (balanced on the original line) has a neutral and stable sound, retaining the HD600's own thick, warm flavour, but with the same transparent and detailed sound quality and condition. Take my familiar Tchaikovsky Piano Concerto No. 1 (Richter version) as an example, usually when I listen to this piece with the HD600, I tend to feel that the intensity and spectacle is more than enough and the detail is not enough, and it is slightly confusing, it will feel more like a symphony than a steel concerto, the piano sound is to some extent covered up within the overall sound, while the HD600 under the C9 drive has obvious The HD600 with the C9 driver has a markedly improved and enhanced sound, with the piano, violin and wind sections being well organised in terms of priority and position, and with a detailed and transparent sound quality that has a very clear overall enhancement and musical expression.
The C9 brings us a sense of experience not only in the realm of large headphones, but also in the pairing of IEMs. In recent years, as technology and materials in the field of Walkman have been updated and developed, the demand for more and more power from the front end of the IEMs has been increasing. The traditional idea that "just any plug will do" has been broken and the driving performance of more and more earbud products is being more and more recognized and considered.
Etymotic Research ER4S
I am putting the ER4S here because I personally love these plugs so much. In the early days, there was a saying that "if you drive the Little Four well, the plug will end up in your head". Of course, this is a joke because the level and number of high-end IEMs in the early years were not of the same standard and scale as they are now, but on the other hand, it does reflect that the ceiling of the ER4 is very high. As a devoted "Little Four enthusiast", I have tossed around half a dozen ER4s and studied each version very carefully before finally choosing this one, the ER4S version, which is "both aggressive and defensible".
In fact, many people have a big misconception about the ER4, that is, the ER4 headphones "good" standard is to drive out the low frequency, I have used a number of bench test, in fact, the ER4 drive good standard is not low frequency, but more loose and solid sound line, unlike many headphones, the ER4 plug drive the better, the more stable and proper sound.
The ER4S driven by the C9, the sound is more obvious to show such texture and trend, the midrange has a certain thickness and higher density, and the sound is no longer the usual state of the straightforward, but more become soft, coupled with the electronic tube mode, the sense of sound line also shows a softening trend, so that the expression of the music is more rich in a sense of content. Especially with the C9 driving, the soundstage space of the ER4 opens up abruptly and is not inferior to that of many flagship IEMs, with clear architecture and spatial transparency. It's fair to say that the ER4 has been transformed by the C9, taking this legendary earbud to the next level.
Oriolus Percivali
The Oriolus Percivali is an earbud with multiple unit types, a combination of moving coil, moving iron and electrostatic units, and a flagship earbud with high sound quality and high tuning standards. To match and drive such a headphone is a comprehensive consideration of the headphone amplifier amplifier, which has to show a high level of quality and tuning, and at the same time make the sound of each unit type harmonious and compatible, which can be a very difficult match.
In fact, the C9 and the Oriole are a satisfactory match. Firstly, the C9 guarantees the quality and sound level of the Oriole to the greatest extent possible, while allowing the details and flavour of the Oriole to come through in their original form. At the same time, thanks to the driving effect of the C9, the sound framework of the Oriolus Percivali is richer and more three-dimensional, with a more pronounced sense of sound lines. While the potential of the electrostatic and moving coil units is further exploited, the moving iron units do not show any distortion or intensification of sound. Such a mutual unity of power and control is difficult to achieve with an headphone amplifier product. Although we don't normally think of the Oriole as a particularly demanding earbud, with the C9's drive and embellishment, the rhythm of these IEMs, which are renowned for their "rhythm", is further fermented and sublimated, making the sound more transparent and textured.
High impedance flat IEMs
In recent years, the high impedance flat head has developed considerably. This kind of earbud, which uses circuit impedance, diaphragm characteristics and targeted tuning as a way to exchange the driving force for sound stability and a sense of field, has gradually gained the recognition of many enthusiasts. I personally agree with this type of product, and this time I have chosen three of the more representative flat-head plugs to review the C9.
The Unyin PK1 is the originator of high resistance IEMs and has been the benchmark and living fossil of flathead IEMs for many years; the Micro Wing zen 2.0 is a super high impedance earbud with 320 ohms; and the Suns 01bu series is actually the most difficult flathead earbud to drive well, although the impedance is only about a hundred ohms. These IEMs have a lot in common in terms of sound, so let's also unite them together.
When underdriven, these flatheads tend to have a relatively dark, muffled sound, and when the soundstage and dynamics don't work, the overall frame of the sound is a little out of shape. If driven by a flagship portable player, the sound is basically at a normal level, but the vibrancy and looseness is noticeably lacking, and the sound can be relatively dull and flat.
With the C9 driving these high-resistance flathead plugs, the sense of frame is further extended and enhanced compared to the flagship Walkman, and the sense of space and force of the sound, as well as the overall layout, is basically primed to reach the level of the big headphones, with a distinct sense of deconfusion and naturalness. At the same time, the sound is much more complete, with much of the content and detail that would have been passed over with insufficient power clearly revealed in the musical context, while the sound has a sense of colour and light, with a significant increase in brightness, essentially achieving the optimum effect expected when the headphones were designed.
Both the lines and timbre of the violin concerto and the grand scenes and majesty of the symphony are clearly and fully expressed, and even in some vocal and pop-like instrumental interpretations, they are highly adaptable and unique.
In fact, there are many other headphones in the review that, in general, have achieved more than satisfactory driving results in terms of drive, control, tonal harmony and tuning relevance. The C9's control and the quality of the sound, especially on the more "driveable" headphones, are what make this amplifier such a surprise. Due to space constraints, I can't go into all the details.
V. Overall evaluation
The Cayin C9 is an headphone amplifier with a high level of design and sound quality. In terms of drive, control and compatibility, it can be said that it is a leader in the long history of portable headphone amplifiers. Of course, when compared to a $10,000 desktop amplifier, the C9 does still fall short to a certain extent, mainly in terms of energy and stability. Of course, this is not a fair comparison in itself, so we don't need to force it.
At the same time, the C9 has excellent control and compatibility, not only for those "hard to drive" headphones with a better level of drive, but also for most conventional headphones, with a high degree of compatibility, not because of excessive drive intensity that causes distortion and distortion of the sound of conventional headphones, but also to allow these headphones to achieve a better sound quality in a more stable performance.
The Cayin C9 also incorporates a lot of unique rhythmic understanding and tuning in the processing of the sound, with its gentle, loose sound style that is both traditional to Cayin, but also has a lot of breakthroughs and innovations, making the equipment have a unique musical sense of expression. This is something that even many straightforward sounding desktop headphones cannot offer.
For the C9, I think it is a great upgrade device for many audiophiles. The C9 is the best choice to break through the bottleneck of the existing portable system, especially for those who have a certain level of player and headphones, and it is the most intuitive, realistic and profitable aspect in terms of sound quality. The C9 is also a classic way to revisit the years of an old enthusiast who has come all the way from the bundle era.
Judging by the current state of the overall technology and market in the on-the-go sector, the C9 is also a once-and-for-all way to listen with peace of mind for many years without needing to upgrade. Even players can seek further breakthroughs and their preferred sound by replacing the originals themselves.
However, it has to be said that the C9 is a more user-specific device, preferring to be a device that breaks the bottleneck further upwards after other devices have reached a certain height. If the level of equipment at the front and back of the system is limited, then the C9 will be able to play a certain amount of space and role, so I think the C9 is still more suitable for players with some audiophile experience and a comparable level of supporting equipment to use, in order to maximize the effect.
VI. New
Over the years, the standard of Walkman players has gotten higher and higher, and the sound has gotten better and more sophisticated. I should say that I feel that audiophiles are now happy to be in an era of such surging development, where audiophiles feel the rapid development of the on-the-go HiFi field day by day and are able to get better sound more easily.
However, if I look at it from my perspective, in the direction of the longitudinal development, I think that today's audiophiles are also unfortunate, because the convergence of player products towards smart platforms has led to a convergence; and the introduction of more and more elements into the field of on-the-go HiFi has also started to distract audiophiles from even putting sound and music in the most important psychological position.
Of course this can't be said to be a problem for audiophiles; audio platforms, multimedia sharing, intelligent operation and full-screen interfaces are elements that were originally good things and are the general trend in this industry and in this field. As one of them, we are of course following the times and trends, and once again going for our true pursuit and purpose in this general context.
Therefore, I think the "purity" that Cayin C9 is proposing this time is particularly meaningful. It is not only the purity of sound that we seek in the C9 headphones, but also the purity of HiFi, the purity of our search for a moment of inner peace in music, the purity of our emotional communication, the purity of the C9 headphones for us, not only the breakthrough we seek in sound, but also the emotion and trust we put into sound and music.
The headphone amplifiers and the bundled portable playback system seem to be a "nostalgic" sentiment, but in fact they are a new breakthrough and expectation in a new environment and era, a milestone and a wake-up call for us to regain our originality and go on the road again.
If we understand the true meaning of the Cayin C9 and project this traditional "HiFi" approach into the new era, we will understand the true meaning of this "purity".
III. Sound overview
1. Power
2. Sound
3. Matching
4. Modes
Oriolus Percivali
VI. New
- Nov 16, 2013
I thought we have clarified that this is not recommended for DX300, so we have intentionally skipped this setting. The high gain balanced line out of DX300 is rated at 8V, while the de facto line out in audio industry is 4V to 4.4V.Thanks, Andy. Please make sure to test with the DX300 in High Gain as well as the C9 in High Gain. I use line out on the DX300 with volume set to 100.
Stay updated on Cayin at their sponsor profile on Head-Fi.
- Oct 14, 2013
According to the sheets here, the C9 input sensitivity is 6V max for balanced in where the Dx300 is listing @ 7.1V maximum.
There were some user mentioning that the C9 was clipping and distorted previously before Andy and others have agreed that the powerful line out voltage was triggering the distortions
Just managed to take delivery of a brand new C9. Paired with my ibasso dx300 in LO mode. I do see that there is an underlying scratching sound across all tracks. I did try both tidal on Android and mango os on the ibasso. The c9 is linked to the Sony ier-z1r. Am I hearing amplified artefacts in the track itself or is it the c9 that’s faulty?
Its not the amp.
Thanks. I do see that once I changed the ibasso line out to Low gain mode the problem seemed to disappear.
Did you set C9 to high gain?
DX300 line out is 3V Single ended and 6V Balanced at High gain, this is significantly higher than industrial standard 2V Single ended and 4V Balanced. When you use High gain line out of DX300, you need to set C9 to low gain, but when you use low gain line out of DX300, you can set to either low gain or high gain.
I was testing the pairing of Hugo 2 and C9. Hugo 2 does not have a true line-out function, so I have to use its regular headphone output as the source to C9. When C9 is set to the line-in mode, I can hear small distortions here and there. Changing the mode to Pre-amp eliminates the issue.
I think someone mentioned a similar problem earlier with other DAPs that do not have a true line-out, and the solution was to change the gain level of C9. However, this does not really apply in my case since I am doing the test with Diana V2, which has to be driven in high gain.
In short, if the DAP does not have a true line-out function and you need power from it, C9's Pre-amp mode is a better choice.
Shawnb
- Dec 2, 2012
So just to confirm before I order some interconnects, they do not need to be grounded?
- Oct 14, 2013
That is correct! I am using mine none grounded. The 4.4-4.4 stock that comes with the C9 is Non groundedSo just to confirm before I order some interconnects, they do not need to be grounded?
Shawnb
- Dec 2, 2012
Thanks! Saves me a few dollars on the cable
- Nov 16, 2013
Thankfully I ordered a Battery Charger at the same time so 'rolling' Batteries will be 'hot swappable'
I will see how the C9 acts without screws to the battery tray as I'm concerned about easy disconnection if moved slightly. Not sure if it clicks into place initially giving one level of security but will judge this when received. Otherwise, one screw will suffice whilst listening to all batteries. Now looking at 4.4mm Balanced Interconnects....
Officially, I have to tell you that you need to apply the screws as described in the user manual. TBH, when I audition my C9 with different batteries, I put the C9 flat on table without the screws and they are fairly secured, but when you put the C9 in vertical placement, or when you hold the C9 and walking around while listening, the mounting screws are definitely necessary.
- Nov 16, 2013
That is correct. I also think that they are regulated to 8.4V rails by the battery tray before feeding into the amp....
So theoretically speaking, if the battery tray is what it is. Then Cayin can make an AC battery tray which consists of bare minimum circuitry for external regulated DC intake.
Then Cayin can also start selling L-PSU as well
That way, you have option of battery module or AC main module ? Who knows...Andy may try to deny it as long as he can.
oooo.... that would be nice.... L-PSU linked to a purpose made battery insert to the C9.... Yes please.... Andy?
I suppose you know the answer, but I'll make your day.
We don't have any plan to design or produce an AC module to replace the C9 battery tray.
- Nov 16, 2013
Hi @Andykong ,
It says "Balanced Portable Interconnect CS-44C44 (4.4 to 4.4 with GND)" on the C9 product page below. (in "What's in the BOX?" section at the bottom)
https://en.cayin.cn/products_info?itemid=135
I believe this means the CS-44C44 is all 5 poles connected including GND. Is it correct?
I'm asking because mine is NOT GND connected. (I have checked the continuity with an electric tester.)
Correct, we make a mistake in our description, we'll correct that ASAP.
The 4.4mm sockets (both input and output) of C9 are grounded, but the supplied CS-44C44 short interconnect is not grounded.
Sorry for our mistakes and we apology for all the inconvenience caused.
- Nov 16, 2013
Hello, I’m getting read to pull the trigger on the C9, but have some questions about how I intend to use it and what’s the best setting, etc.
Desktop: I have a Topping D90/A90 stack connected via XLR. I believe I could have two options: 1) D90 RCA output to C9 3.5mm input and use C9 in line mode, then volume controlled on C9. 2) A90 XLR preamp output to C9 4.4mm input in Pre mode, then volume is controlled on A90. Are both of those correct? Would one be better than the other in terms of sound quality?
Transportable 1: iFi Micro iDSD Signature RCA output to C9 3.5mm input. I believe the Signature can only be used as fixed output on the RCA out, so Direct would be the only option. That one seems straight forward.
Transportable 2: I’m in between DAPs and currently leaning towards Shanling M8. Does anyone know if the M8 has a true line out? Would I use Direct or Pre with M8 for the best pairing?
Thanks in advance!
Once again, please DO NOT use phone output of desktop headphone amplifier as source to C9 Pre-amp input mode. We must remember the basic different between pre-amp output and phone output. Pre-amp output is by definition voltage gain without current gain. You likely will end up with a lot of background noise or even distortion if you use high-power phone output here.
I'll quote my own explanation regarding Phone out as Pre-out:
If your DAP don’t have line out option, that will limited your option to upgrade your system though an outboard headphone amplifier, using phone out as pre-out is probably the best bet. Theoretically, that should be better than turning the volume to maximum and use it as line out because you are operating your DAP at a lower distortion level and SNR. On the other hand, since pre-amp output is by definition voltage gain without current gain from line out, so phone output with smaller current gain will likely perform better than phone output with higher current gain; a phone out with lower output will likely work better then phone out with beefy output. The Sony WM1Z and WM1A probably is one of the best example of this scenario, please refer to Headphonic C9 review (https://headfonics.com/cayin-c9-review/3/) for more detail about this combination.
In other word, only DAP phone output with relatively "smaller" current gain can be used as a substitution to Pre-amp input. If some of the DAP phone output are consider too beefy for this application, then we can almost certain that the phone out of desktop headphone amplifier is not going to work.
- Nov 16, 2013
Now I can carry the C9+A02 stack with me wherever I want. There are a couple keys that I want to confirm
With HeatSinks 4X and Class AB Solid State
The C9 can only get warmed enough while staying inside like this after a couple hours or so. Therefore, the C9 under this arrangement can be taken on a bike ride , a walk in the park, or walking the dog while enjoying music like you have never had done before.
There are so many different ways to carry it, but most importantly would be to find a shoulder bag that fit your style. I had to slightly cut the opening more open on this Case style. It is $40 or so, and is totally worth it. You may want to get a little larger one of you don’t prefer cutting the Zipper out of the new case
https://www.amazon.com/gp/aw/d/B08BFGB53J?psc=1&ref=ppx_pop_mob_b_asin_image
I am kind of worry that the zipper will scratch the C9 chassis when you put it in or take it out of the pocket.
The amazon link suggested that this is a leg bag, which mean you can wear the bag on your waist, and then tie the lower belt of the bag around your leg. I assume this is not a good design for cycling but if someone want to use it for hiking or when you want to left both hand (and shoulder) available while jogging, a leg bag that warp around your waist maybe a good idea. By the way, my leg bag (photo below" is bigger than yours, suddenly I feel proud.
- Nov 16, 2013
I am still waiting for the answer on the 4.4mm socket line in. Will it go into differential stages if single ended was to connected into it, or is Differential stage applicable only toward the 3.5mmOh, I see what you meant now LOL! Ok, that makes senses. It is the current limits of the battery tray and if it has 30A limit, then using 35A limits battery would not bring benefits. Agreed, definitely a good question for @Andykong .
I checked with our Engineers, the SE to BAL conversion circuit is designed to work with the input detection mechanism. C9 will detect whether you have inserted 3.5mm or 4.4mm connectors as input and output, and invoke appropriate conversion when needed. The detection involves applying a very low level signal to the Ground contact area (for both input and output 4.4mm socket, that will be the Sleeve of TRRRS). We cannot detect whether there is an active signal in L- or R- because that will involve applying a very low level signal to these two "rings" and this will introduce background noise that might be audible at low output level.
For these reasons, we always assume the input signal is a balanced signal when we plug a 4.4mm connector into the balanced input of C9. We cannot detect the absence of L- and R- signal and therefore cannot support a 3.5mm to 4.4mm adapter cable as C9 input properly.
Total: 12 (members: 0, guests: 12)
