dBel84
Cavalli Tinkerer at large
- Aug 5, 2006
Thank you. Sounds transportable to me. Still confused about the tubes. Even if I don't get quad set I guess I should get dual matched sets, otherwise there will be channel imbalance, right? Would also like some mix and match of tubes done, so would be grateful to know how many stages are there are and how many tubes for each stage. Many thanks.
It is not like normal tube amps where you typically have stages , but you could extrapolate it loosely to 2. I would not recommend mixing and matching either. if you get 2 matched sets , use the matched sets in the same position for each channel .
Does anyone read German?
Happy Thanksgiving to the folk who celebrate ..dB
