Gigabomber
- Jan 28, 2005
A simple tip to buying a car is to buy one that has had the same model for a long period of time. They work out a lot of the defects (if they are a good company) over time whereas new models are often hellish simply because of the lack of time on a vehicle. You buy any car, from a decent company, with a model that has been around ten years with a high ratio of good to bad consumer reports and the test drive fits and your decision will be more fruitful in the long run.
In other words, staying away from new models - like the mustang - is generally a pretty good idea considering the chances that your willing to let it sit in the shop for a while and deal with their defect-checking process.
Then again, some cars are just made better than others are you might get lucky.
If you buy a new car, make sure you get one that is built during the middle of the week, may be able to dodge a couple bullets that way due to avoiding the workers monday blues or friday rush.
Course what do I know, I sold my 99 cadillac and kept my 75 buick,
Good Luck
Good Luck
