psychogentoo
- May 27, 2004
There are no "chips" for the 8 to give you great gains and it will NOT silence the "not enough power" crowd. There are a few piggy back ECUs (acting as an abstraction layer), the one that comes to mind is the Canzoomer. From my research, to get the Canzoomer to work properly you have to do some fine tuning with it hooked up. Even with the tuning its not going to give you a drastic improvement in performance.
There is also not much in aftermarket FI kits available...yet. There were rumors of a mazdaspeed FI but nothing has materialized except for a concept by the mazdaspeed team. Even with the supercharger, the numbers were very modest. Hopfully someone will come out with a reliable turbo (electrically assisted or otherwise) or supercharger setup in the next few years.
I will also do you harm if you get the auto 8. Its a different engine all together. sure its the same 1.3 liter but it has two less ports and the redline is at around 7.5K. The 238HP is gained at 9K.
Make sure you get the DSC/TSC option. You can always turn that off when showing off for your friends or doing autocross but may save your life when driving on wet roads going school or work.
If you do get the 8, make sure and check your oil every time you fill up...also wouldn't be a bad idea to have an extra quart of oil in the trunk.
good luck in your car search!!!
