iLikeJarJar
- Jan 8, 2011
I just got the Beyerdynamic DT880 600Ω version, along with a FiiO E9 amp. The problem is, the volume isnt very loud and it has less bass than my AT A700s. Whats wrong?
DT880's aren't known for their bass quantity
I agree with this...on paper the E9 puts 80 mW into 600 ohms. Read that again: 80 milliwatts into 600 ohms. That is a TON of power. You're definitely going to need to flip the gain switch on the back of your E9 though, it should be pointing up to indicate that it's on.
As a disclaimer, I've never heard this can (I have the E9), but based on the technical specifications of the DT880 and the E9, you should be able to blow them off of your head...
If you are one to consider 6Moons a trusted source, in their Asgard review they noted that the Asgard at 260mW @ 300ohms / 130mW @ 600ohms was not ideal for those impedances. Here is their chart - http://www.6moons.com/audioreviews/schiit/5.html
What can it drive? For most meaningful context, I used my 160GB Classic iPod in a Sieben Technology dock directly into the Asgard. That's a 1V max source, i.e. half the signal strength of a conventional CD player. Substituting a high-output DAC like the 10V Burson Audio HA160D or 5.5V Weiss DAC2 would obviously completely upset/reset the following list for achievable SPL but not raw drive.
Code:[size=12px] TECHNICAL SPECIFICATIONS [/size] [size=12px]Impedance....................600Ω [/size] [size=12px]Nominal SPL ..................102dB(1mW/500Hz)[/size] [size=12px]Power handling capacity. . . . . . . . . . 300 mW[/size] [size=12px]Max.SPL .....................126dB(300mW/500Hz)[/size]
Actually, what are you using as a source? I'm using an EMU 1212m soundcard, with output volume set just high enough that it doesn't clip (it has little warning "leds" to let you know if your source streams are clipping).
Quote:Actually, what are you using as a source? I'm using an EMU 1212m soundcard, with output volume set just high enough that it doesn't clip (it has little warning "leds" to let you know if your source streams are clipping).
The EMU-1212m states it is -10dBV nominal output. This is about 0.77Vrms, which is very low. It's not surprising, sound cards usually have either a 5V or 3.3V source voltage to play with as a power source....which isn't much.
