I am interested in the Andro, but I have the S-EM9 and soon Prophile 8 that have comparable positioning as the Andromeda, i.e. balanced sounding BA. So I am more interested in the Vega.
Did you finally get rid of the Hum Pristine? That is one iem that I wanted to audition. Also, the Andro is very different from the other BA, just different.
You just attach to your current cable? Nice. I'm going to order them.
I have a balanced whiplash TWag modular, but I didn't hear a difference on my Fiio X7 with Vegas. I really believe it is more the fault of Fiio. Not a fan of their balanced setup. Seems like it does nothing.
Yep, this is the beautiful sparkling crystal cable. It seems to open up the sound a little bit and tighten up the bass even more compare to the stock cable. The stock cable is very good also.
That is true. Not too many people work with the Crystal cable. Years ago Peter from DHC sourced some Crystal Piccolino cable for me but even him did not want to make iem cable for me at the time. I ended up with some raw Piccolino cable, then I was at Kimber Kable and they used the material that I have and made some cables for me. So I still have some materials to make some nice cable. But crystal cable is different. I was in HK couple of months ago and some stores carry them. They are the ones made for AK and they come in MMCX connector.
If CP-100 are the smaller bore size of their two versions, then I can confirm they fit. Spinfit cores are pretty elastic anyway so they normally fit on most gear with enough work!
