I've just begun listening to the Vega (thanks to an awesome head-fi'er). I really like the moving-air thrum it gives to the bass, and really every part of the range.
Does the K10 has more treble than vega? or equal or less..
Vega's got delivered to the house today so I went home from work for lunch and picked them up. Back at work and giving them a listen through my Galaxy Note 5 and wow, they sound great already. Gobs and gobs of detail and thumping bass. Can't wait till they are fully burned and running off a decent source. But they sound great even from a smartphone streaming Spotify.
I have been flying a lot the last couple of weeks so I have a lot of time to listen on the airplane. What I realised is that I really need both Andro and Vega to be satisfied. After you listen to one for awhile you'll yearn for the other and vice Vera. I think it will be especially true with the 1Z that you have. It is like lobster and steak you've got to have both
Everyone seems to say that burn in time is roughly at least 100 hours. But some go further. I normally burn at a low volume at the start and get louder to my normal listening volume as the hours move past. But since I'm already past the 100 hours, I don't worry about burn in or any of that stuff.
I have reached the "official" 72 hours burn and probably half of that in listening time. I have been a doubter in the past, but burn in does matter things do settle the most obvious being bass are tighter and more defined. I'd say treble is getting better too, I feel they render more subtly and I don't have the hints of mettalic-ness I occasionally experienced initially. The slight sibilance is also fading away progressively but further tip rolling might fix that. I gave the RHA dual density tips a try, they do fare better in that regard. Some mentionned the SpinFits in the box being rightly sized for the 4mm bore but I can't even fit them, too narrow and I don't wan't to apply force (not to mention, the narrowness will partially obstruct the nozzle.
I have a feeling further burn-in will make the Vegas even better, we'll see!
If Vega has more treble than K10(UA) then that's not good. It's probably harsh and sibilant to me. K10(UA) is as bright as I can tolerate.
Hi Jalo, how was the isolation with Vega while you were listening on the airplane? Does it block enough noise so you can enjoy the music without noise cancellation headphone? Thanks.
