MidFiMoney
I bought the Fidue A83 Balanced based on good feedback in this thread. Thanks !!
Does anyone know how long it takes the cable to arrive HK -> US East coast ?
Good choice!
I am very close to buying the Lyra II off massdrop.
How comfortable is the cable from campfire audio. I know it well made cable but is it heavy? Is it light and flexible? can it be worn with glasses?
TIA
Good choice!Mine took about a month to arrive but that's because it was shipped to a U.S. base overseas. So, it had to be mailed to the states, sorted and mailed back overseas haha. I'd I guess you have to wait a couple weeks-ish?
The litz cable is very nice. Lightweight, flexible,not prone to tangling, very low microphonics. Almost certainly worth the $150 standalone asking price.
As far as glasses, I can't answer that one, but the cable does have memory wire if that gets in the way when wearing glasses.
I don't own any aftermarket cables (except the alo ref 8 that should be arriving tomorrow) but it's much nicer than the cables that came included with my other iems, and since I know you have the lz a4, it's much nicer than the a4's included cable. The only "issue" I think will just be whether you like or dislike memory wire. Personally I used to dislike it, but it doesn't bother me much on this cable.
try the Onkyo Player App.The Fiio X5 III + Vega is blowing my mind.
Caveat: The X5s are new, I will post after the honeymoon period is over.
So I've been having been having issues with the seal on the Vega. No, this is not a Vega issue. I usually prefer the short wide bore silicone UE900 tips with most of my IEMs. However, these tips cause a weird seal that kinda backs my ears up with pressure. I feel like my eustachian tubes can't drain properly and my ears feel blocked even after I remove the earphone from my ear. I'm assuming it has something to do with the shape of the tips and insertion angle, not allowing enough air to escape when inserting the earphone. I experienced the same same thing with the FLC 8S. There's just something about the nozzle design and the UE tips that just doesn't jive.
After some extensive tip rolling, I reluctantly tried the included foam tips for the first time. I never really had luck with foams in the past. Either they felt weird in the ear or altered the sound too much so I usually don't even bother with them. To my surprise, the stock foams didn't really degrade the sound but did tame the treble a bit and bump up the isolation. They're also pretty comfy! I feel like a knucklehead because I know KB tuned these with the foams in mind and specifically said to try them with foams haha.
Anyhow, I'm pretty content with the stock foams but I am curious if there are better foam tips out there I should be trying out. If so, what changes can expect over the stock foam? Thanks!
guys quick question:
of the andromedas or the vegas, which has the widest soundstage and best separation of instruments, please?
(I have the FLC 8S and i find the sound stage a bit compressed.)
