What do you guys think are the best pair of Campfire Audio IEMs for their price?
orion or jupiter imo
I've only tried the Jupiter, Andromeda, and Vega. All fairly pricey but the more I listen to the Vega, the more I like it and to think the sound is coming from a single dynamic driver really impresses me. My guess is that the Vega is the current king of the dynamics so I'd have to give it to the Vega even at $1300. However, the Andromeda performs very well against more expensive BA IEMs so you could easily make the case for them as well. I wasn't overly impressed with the Jupiter. I've come across a few IEMs at equal lesser value the edge them out IMO. My experience mostly leads me to believe CA IEMs are fairly priced for the most part. Picking the one closest to your budget and sound preference is probably going to be a good value no matter how you slice it. They also sell b-stock that is marked down considerably. At $850, the Andromeda is pretty much a steal IMO.
https://aloaudio.deals/
Where can you buy the b-stock from?
Are there any other IEM companies that sell B-stock like this?
I've had and loved the sound of the IE800. Sold them due to poor fit for my ears. Has anyone compared them to the Vega? I specially loved the trebles in the IE800 and it would be great if they are as clear in the Vega...and before anyone asks, no, I can't test them as no one sells them locally
Thank you!
Thank you!
Thank you for the feedback. Andromeda aside would the Dorado be a bit brighter?
It's so difficult to buy without testing!
Yeah it is hard to choose without a listen, you can check out @flinkenick
review of the Dorado and Vega there are some comparisons also to Andromeda
I have never regretted trusting Nick
Dorado has the same TAEC chamber the Andromeda has it might be an interresting option indeed.
If you check out my review of the Vega or Dorado (in my signature if you are viewing on a computer) on the Head Gear section, there is a comparison between the two. The Dorado is definitely more sparkly due to the dual BA up top, but loses out in the mud in a straight shootout do it ready depends what you are after.
Both are comfortably along the best IEMs I have heard so far in my audio journey, so neither erupted be a disaster (to put it mildly).
