Raketen
- Apr 5, 2010
If only there was the opportunity to get another run on the MW10. What’s this new Andromeda?
I might be wrong but isnt' the Ara supposed to be based on MW10?
The Ara is the most reference tuned of CFA's lineup but it is based off of the same internal architecture as the Andro Gold. The Andro gold on the other hand was a more excitable Andro tuning with the additional 2 BA's for the bass and the crossover-less design but went in a different tuning directly than both the Andro and Ara (more toward the Dorado 2020 if anything but all BA).I might be wrong but isnt' the Ara supposed to be based on MW10?
Are they really different directions? Andro Gold definitely has more bass compared to the Ara but they seem to be more similar than different.Andro Gold and Ara definitely in different directions tuning wise. Unless one wants to play count the BAs game.
One focuses on the low end and one on the higher end.
Gold is a real basshead jewel with excellent midsAre they really different directions? Andro Gold definitely has more bass compared to the Ara but they seem to be more similar than different.![]()
Appreciate the link. Great website/ review site. I think some of your reviews and observations in the past are what compelled me to buy both the Andro Gold and Andro 2020 in the first place. I have not heard the Ara but recently purchased a Solaris OG and I think I like that item best of all.You are right.
Also check out my antique listening notes if you wish:
https://www.headpie.net/2020/06/campfire-audio-ara-andromeda-2020-and.html?m=1
<3
If somebody is interested I'm selling my pair of CA Andromeda Gold
https://www.head-fi.org/classifieds/campfire-audio-andromeda-gold-le-extras.27611/
Using the XINHS 8 core graphene cable with my andro 2020, having good results with it so far, however it can be a little bit thick. There is also a 4 core version which is lighter (and cheaper).Any good recommendation for a MMCX cable for the Andromeda from XINHS ? I would like it to be as close to the stock cable as possible, thanks.
Should there be any difference between 4 and 8 cores ?Using the XINHS 8 core graphene cable with my andro 2020, having good results with it so far, however it can be a little bit thick. There is also a 4 core version which is lighter (and cheaper).
