Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
post-15034232
Post #7,201 of 8,850
smok88
Sydney
Sydney
Im so intrigued with 3 comments with the same idea of SXC 8 gives a better air and bass to andro. How s the soundstage and how s the sound separation.
Does it worth buying the cable instead of M11 as a DAP? Im planning to buy dap but if it doesnt change the sound, im okay with the current setup and get the cable instead.
I have had the SXC for just over a week and have burned the cable in with over 100 hours non-stop music playing before I had a critical listen. To my ears, the soundstage is very similar in size as the stock cable. SXC adds "meat" to the bones so to speak when compared to the stock cable. The stock cable is very good as it is but the SXC gives it more bass (not overpowering the rest of the mid or treble frequencies) and the sound is "fuller" and more musical experience, With the SXC, the experience is closer to my HD800 but the soundstage of the HD800 is still wider and the best - HD800 is also alot deeper with voices further back than the Andromeda.
I did say earlier that I ditched the iEMatch with the SXC but I now use it again as I like it better with the iEMatch - even though hiss is reduced with the SXC, I can still hear it and it is annoying to my ears.
Is the SXC better than a DAP upgrade, I can't say. It depends on a lot of things, like is the DAC chip and headphone amp on the new DAP better than the old DAP DAC and headphone amp etc. I use the SXC with Andromeda with my iphone 8 Plus and the Dragonfly Red and the iEMatch and it sounds very much a premium hi-fi IEM experience. The only downside is the SXC is a thick cable (and stiff) and quite microphonic to movement noises - so if you can ignore the downside, it is a very good cable that enhances the Andromeda sound signature.
Reactions: twiceboss
post-15034252
Post #7,202 of 8,850
twiceboss
Thanks for the reply. After having some readings, i dont think im gonna do any investment on cable. Most of them happens due to different resistance. Yes, it will change the sound due to different resistance making different total of OI. So it makes sense that it changes sound.
I perhaps will do tip rolling. Cheaper and the sound is obviously different for each of the tips!
edit: except buying cables for their aesthetics or functionality eg. short cable for es100 pairing
Reactions: Jayden16
post-15035930
Post #7,204 of 8,850
twiceboss
Anyone tried the Spiral Dot ++ with the Andros?
Im using it right now. Listening to is ffkingg awesome. Sound separation and soundstage is unbelievable!!!!!!!
Spiral dot is my main tips with any iems
post-15036032
Post #7,205 of 8,850
Peter P.
Philippines
Philippines
Yes they are the best with the andros. Tried the symbios etc the spiral dots sound really smooth without any sibilance as well.
post-15036327
Post #7,206 of 8,850
Mirimar
Australia
Australia
You guys referring to the original Spiral Dots or the new Spiral Dot ++ that have just been announced?
post-15036394
Post #7,207 of 8,850
ExpatinJapan
Hell
Hell
A2F286C5-02B9-4385-85C2-9572AFBA4A4D.jpeg 6B693DBD-7FEB-47DE-8B48-A063B11BCB7C.png
I have the new Spiral Dots ++ and are using them on my Andromedas
(I also have the original)
Reactions: Mirimar
post-15036422
Post #7,208 of 8,850
mattiav
What's the big difference? From what I can tell, the original spiral dots have a wide bore, which (based on my experience with the Final E tips, i.e. comfortable but don't do it for me sound-wise) would seem better than a narrower bore on the ++ model. Am I missing something? May try some out once the prices come down to something non-absurd, and I figure out what size I need...
post-15036485
Post #7,209 of 8,850
ExpatinJapan
Hell
Hell
Physical differences are the inner core/stem is color coded on the ++.
It also seems to be slightly firmer and and have a better lip to grip the IEM nozzle for a better seal.
The ++ outer is more a smoother matt and soft feeling (but still firm) finish, whilst the original has a more shiny harder surface.
The original has good body when a correct seal is achieved with a slight V.
The ++ has more mids.
@audio123 care to weigh in?
As can be seen above the size is generally the same. The bore opening is generally the same if not identical.
Above a comparison to the (original) Andromeda Silicone tips - not sure if they have changed. And the original JVC spiral Dots.
post-15036854
Post #7,211 of 8,850
audio123
Reviewer at audio123
Comparing Spiral Dot++ to Spiral Dot, in brief, bass is more clinical, midrange more energetic, airier treble and bigger stage. :)
post-15041101
Post #7,212 of 8,850
marcus2704
Anyone know where I can buy Spiral Dot++ tips for my Andromedas? I am in the UK and I cant seem to find them anywhere.
post-15041110
Post #7,213 of 8,850
phiemon
I have the same problem here in Berlin.
I think, we can just buy on eBay for about 50$ which is very... too much for me!
post-15042257
Post #7,214 of 8,850
theveterans
Santa Rosa, Laguna, Philippines
Age
29
Got me curious to try it since Symbio W currently is the most transparent tips I’ve tried but I do agree that while it does not tame sibilance in the recording, it sounds very smooth, wide and spacious when it’s deeply inserted
post-15042448
Post #7,215 of 8,850
twiceboss
More soundstage and airier? damn take my money. I dont find it on amazon though....
Reactions: audio123
Users Who Are Viewing This Thread (Users: 1, Guests: 4)
  • hsdw
