Hanesu
Thanks for the details!!! I will eq this for certain tracks and not eq it for the other tracks.
It's true that it's impossible to get the open ness of hd800. Hd800 is also rated as the biggest soundstage in headphones territory.
I'll be doing more listening and eq ing this until i got the sweet spot. And also, the tip selection is also very crucial. The final tips give less soundstage but better bass and less fatiguing highs. Jvc give better openness and less bass.
So now im curious, what kinds of tips those are recommended for the tips rolling for andro? I just order a symbio W too.
Let me know what tips can give the best openness with andro! I would make it an instant buy for sure haha
Well, I think the general rule to get more stage with IEMs through tip rolling is: More distance from the eardrum and slightly looser fit. In other words: Tipps with long stem or foam tipps, for example. Downside is that you might loose a bit of the crispness. I personally have used spiral dots because I simply got the best fit and seal with it. Since they are very short you loose a bit of the wide stage (vocals get closer).... but very clear and crisp on the other side...
