EternalShadow
- Oct 7, 2005
Really feeling the urge to grab the Nova. Someone, please review! We get that the Andromeda is out of this world, lol
This is how I hear CFA Andromeda vs Noble K10UA (using LPG as a source).
Soundstage: both have a very similar depth/height but Andromeda is noticeable wider, with a more holographic sound effect. Both have great separation, but layering effect between instruments and vocals is better in K10UA due to its brighter nature with more airiness.
Bass: Andromeda has a better sub-bass extension and more quantity in comparison where K10UA sub-bass is a little rolled off. Mid-bass punch and speed are nearly the same. Overall, K10UA bass sounds a little tighter and a bit leaner (due to less sub-bass), while Andromeda's sub-bass quantity beefs up the low end, giving it a more analog quality. Both are well controlled, no spillage into lower mids.
Mids: K10UA lower mids are leaner and have less body, while Andromeda lower mids have a fuller body in comparison, but not too thick. Both have a very detailed and revealing upper mids, but Andromeda is smoother and a little more organic in comparison. With Andromeda I hear not even a single peak which contributes to graininess or harshness while K10UA can get a bit hot with a few of my brighter tracks (this one is purely subjective opinion). I also think that due to a fuller body, both male and female vocals sound more natural on Andromeda.
Treble: Both have an excellent treble extension with a great definition, but K10UA treble is a little brighter and with a more crunch. Neither sound sibilant, though K10UA can get close (but never crosses that threshold) with a few of the bright tracks (I'm allergic to 5k peak ). In comparison, K10UA has more airiness, but Andromeda is not too far behind.
Both have a relatively balanced signature while Andromeda has a slightly warmer and smoother tonality in comparison to K10UA. Both, Andromeda (5xBA drivers) and K10UA (10xBA drivers) are very detailed and highly resolving and definitely worthy of a flagship status.
From the frequency response of Nova, it looks not attractive. It doesn't even reach 20kHz (40dB).
It is even worse than Orion (http://www.6moons.com/audioreviews2/campfire/4.html) with that -30dB jump at around 12kHz.
Great thanks - I'm guessing it was "white tape" version looking at the graph. I can see why you went with it - compared to Jupiter (for me) its a massive improvement. Nova looks really good (graph) - very much my kind of sig. If dMarc0 running an Australasian tour, I'd love the chance to review them.
And if you do end up doing a tour with them - if could measure his particular pair before you send, and email me the CSV freq,db pairing for the entire freq range on the Nova - I'd love to use it to calibrate my Veritas. I'm reasonably happy with the way it measures below 4 kHz - but beyond that you're 100% right - measures way too low. I could do it manually - but would be very time consuming, and not as accurate as using your measurements as a calibration guide.
Re the shells - I've worked out why a few have issues and others don't. Tip dependent. If I use a narrower tip, I have to try and insert further, the housing presses on the ear, and it's uncomfortable. A wider tip, and they sit slightly off the ear, and the edges aren't an issue. With a shallow fitting ergonomic design it can be an issue I guess. Another option might be to lengthen the nozzle slightly. Just food for thought.
Oh and to shockwaver, the Andromeda I heard wasn't V shaped. Quite balanced overall.
Campfire Audio - Nicely Done.
Stay updated on Campfire Audio at their sponsor profile on Head-Fi.
Are those k10's? They look like Savannah's.
Following this thread with rapt attention for some opinions on the Nova. ;_;
