ncristia
- Mar 19, 2014
Is the 2.5 Litz ALO cable balanced? Will it work in balanced mode with Opus #1?
Thank you
yes and yesyes and yes
Thank you
Are there any cables out there that have a right angled 2.5mm balanced cable without the memory wire? Most cables have it as a straight plug option only so was wondering. The reference 8 cable would be a good option if not for the memory wire.
Does the tinsel cable show any signs of memory retention or tangleness compared to stock litz?
Is it balanced? It is TRRS. Maybe for a microphone attachment.I just noticed tinsel is the only option for 3.5mm TRRS bal. Does the tinsel cable show any signs of memory retention or tangleness compared to stock litz? Thinking about ordering it as I already ordered the IEMatch already.
Definitely yes it does.
If you look at Andromeda reviews, invariably they praise the Litz cable compared to the Tinsel cable due to ergonomics.
Tbh I dont know.
Best to email first.
Agree about the ergonomics of the litz cable. In terms of ergonomics, best cable I've yet had a chance to use. Supple, flexible, and strong; the only thing I didn't like on it was the memory wire, which just about everything for over-ear has (and it annoys me).
Mine came with unmatched length of the plastic sleeve over the memory wire. One side is a little shorter than the other lol
I can't be sure, but maybe mine might have been similar, though it didn't matter either way. Just having it on there annoyed me regardless of matching length or not lol. Every other part of the cable though was fantastic. If they had 2-pin available, I would consider it (consider rather than definite buy since it's still kinda pricey for a cable, at least to me)
I think it really depends how big your ear is and how perfect the tips fit in your ear. If the fit is just slightly too big, memory wires are very helpful to keep the IEMs in place which is the case for me. You wouldn't really need it if the fit is already perfect and that happens when I use smaller tips (doesn't provide adequate seal though).
It's just worked out well for me then. I haven't had a single experience where I found memory wire beneficial; it's always been an annoyance. Even with the CA line which, aside from CIEMs, have probably been the largest shells I've put in my ears. I usually use small tips, sometimes mediums.![]()
