Tweaked my Linum BaX cable with new pin and jack (the default jack is goner btw), looks almost perfect with my Nova, if only the color of the pin is a bit darker.
I have the 75 ohms etymotic adapter, also the Hifi-m8 which has an impedance switch of 11,2,1 ohms.
Posted back in June.BRIEFLY tested the Andromeda with the Centrance Hifi-M8 and its impedance switch with 11,2,1 output impedance options.
1ohms OI: is as expected, the full Andromeda experience. everything sounds beautiful and well tuned/balanced. smooth.
2ohms OI: Slightly reduced bass and less controlled, Vocals lose some crispness. A slight Harshness underneath. It becomes more flat and less musical, loses that magic it has. Still sounds good,very close except with critical listening. some may prefer this setting.
11ohms OI: A different sound signature all together. Quite thin overall. Reduced bass and mids, weak vocals. Some who heard a device at this setting might describe the Andromeda as laid back.
This is not a criticism of the Andromeda, more just an example of how all BA and mulitdriver IEMs need the lowest OI 1 or less to perform at their optimum.
Imho
regards
Expat
Back in June.
@LouisLoh
Sorry I dont have the time the go further with this currently as I have about five earphones, a bluetooth cable and one Dap etc that are backlogged for review on my blog that I am writing at the moment.
(My Campfire Audio Andromeda, Jupiter and Nova reviews are on their also).
If you are happy, thats the main thing.![]()
Enjoy.
I also briefly auditioned the V5 at a Canjam and agreed that it is very good. I made the comment to Ken that it sounds as good as my Hugo and he seemed to be pleased to hear that. With regard to bass, my first awakening to bass from headphone was with my first LCD2, I love clean tight bass that hide themselves until they are needed or present themselves and when they do, they do not color the whole frequency range and make the sq warmer and caused the treble to loose the sparkle and airiness like so many iems/headphones do. The Andromeda does this beautifully and that is the hallmark of a good phone.
Yeah basic head fi 101 rule.No worries. I would have been happy to engage in a discussion if you had a recent listen.
Glad to know you are making recommendations based on distant memory and what you think the combination may sound like, especially since your assertions were pretty bold.
FWIW, a quick 5 minute listen would suffice, because the differences are quite prominent.
I don't really understand, it is an amp, whether it sounds as good as the Hugo would entirely depend on the source.
What I mean of course is given the same source and comparing dac/amp to dac/amp.
Tweaked my Linum BaX cable with new pin and jack (the default jack is goner btw), looks almost perfect with my Nova, if only the color of the pin is a bit darker.![]()
Awesome work! I hope I could do that with my nova and linum bax.
hi
plz comparison campfire ANDROMEDA vs earsonic S-EM9
Anyone has experienced distortion with one side of the Nova?
So yesterday, I started hearing audible distortion on the right side of my Nova. Vocal is followed by static noises. This doesn't happen on the left side. The distortion is worsen if I touched the Nova housing, like it takes conductivity from my finger and amplify the static noise I'm hearing. Very weird...
Today, I downloaded a sine generator app on my Android phone and try to find the frequency where it is affected. The distortion started to be audible at around 1.2 khz, got really bad at 2-3 khz, then started to disappear at 4 khz, vanished at around 5 khz.
I bought the Nova from Massdrop exclusive launch, is the warranty covered by Massdrop or by Campfire Audio directly?
Campfire Audio - Nicely Done.
Stay updated on Campfire Audio at their sponsor profile on Head-Fi.
